Question about Husqvarna Garden
Husqvarna cth 160 running slow - Husqvarna Garden
SOURCE: we have a husqvarna cth 170 and we cant seem to
I have a Husqvarna YTH2348 that clicks when i try to start... I had the battery tested and changed the solenoid and still won't start. How do I check the starter????
Posted on Jun 07, 2009
mickey813
  • 472 Answers
SOURCE: husqvarna cth
sounds like it has something inside the trans that needs to be fixed i would say you will need to take that in to a shop to have it fixed
Posted on Oct 16, 2009
  • 3 Answers
SOURCE: I have a Husqvarna CTH 171. When i engage the blades they
Does the lever that engages the blades have pressure on or does it feel loose. It is possible that the linkage from the lever to the idler pulley has come off. Raise the hood and watch the lever as it is engaged and disengaged there shold be somekind of linkage moving a pulley in and out to tighten the belt so the blades will turn. hpope this helps
Posted on Mar 03, 2010
  • 3911 Answers
SOURCE: need the manual for husqvarna
did you try a google search? if you do that, you will find it eventually instead of asking someone else to do it for you.
Posted on Feb 09, 2011
SOURCE: Need a new drive belt for a Husqvarna cth 130
hi I've oil getting into air filter,why is this happen?
Posted on Mar 26, 2011
Hi Team. I too need a diagram to install the belt on my 2007 Husqvarna CTH2036 cutting tray. Can you help please. serial. 082207C001009. product. 960610217 01
The CTH machinesw have counter rotating blades, there should be a scimatic of the belt routing on the underside of one of the foot wells
Dec 03, 2012 | Husqvarna Garden
Husqvarna cth 180 the shaft as brocken on the rear axle can I replace it
to replace it you need to remove the rear assembly then open the rear axle assembly
Jun 16, 2012 | Husqvarna Garden
Hydrostatic on husqvarna cth 180 xp losing power
Check the drive belt. This belt runs from the engine to the transaxle. Look for abnormal wear and if the sides of the belt look glazed/shiny. Check the pulley mechanism that tightens the belt for proper operation and belt tension while engaged.
Try reducing the speed selector. This is equivalent to running in a lower gear. Your tractor works hard just to turn the blade. Going uphill requires additional power, so some reduction in speed is to be expected.
May 06, 2012 | Husqvarna Garden
I have just bought a second hand cth 180 xp. It's
you will get all that on the engine manufacturers web site under that size engine
Jul 08, 2017 | Husqvarna Garden
CTH 171 Mower starts and runs fine but lacks power to climb even gentle slopes whether or not it is cutting.
The mover has great vibration as all mowers do. That is why the valves are recommended to be regapped at every 250 hours of running time. If not checked the engine will run although will be reduced in power going up a grade. Eventually it will not start so easily if not serviced soon
Jul 09, 2011 | Husqvarna Garden
http://weborder.husqvarna.com/order_static/doc/HO/HO2005/HO2005_5321938-34.pdf
This is the owners manual if you do not have one.
There is a brake on the pulley, make sure that is not hanging up.
Please let me know what you find.
Feb 08, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna cth
Sep 02, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Need a new drive belt for a Husqvarna cth 130 hydrostatic ride on mower how much are they
Depending on where you live they cost between $30.00 and $50.00 dollars some are as high as $75.00 becuase of the type of belt that it is.
Aug 19, 2009 | Husqvarna Garden
We have a husqvarna cth 170 and we cant seem to reverse it... have any ideas on how?
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Jan 23, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
49 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
