Question about ASUS Transformer Tf300t Tablet
My Asus Transformer Tft300 won't boot. It is stuck in booting mode. I have tried numerous times to power off and back on. Often it will power back up on its own, after I have powered it off, but it remains in the boot mode.
  • Jeff Petersen Aug 01, 2013
    This has been resolved. I had to use the data wipe function but now the tablet is functional again.
2 Suggested Answers
gamestoysman
SOURCE: My asus transformer tf300 won't turn on
It is possible you got into APX mode (for transferring files with the device not in the OS using NVFlash. Great if you bricked a device). This mode is Hold VOL UP and tap POWER. In this case, you can try to use the Reset Hole on the left side of the Asus TF300 (between the microHDMI and microSD card). Try it for 3-5 seconds. Another thing you could do is hold the power button for 30 seconds, release, hold it for 3 seconds and see if it boots.
The last thing you could do is hold VOL DOWN and POWER for about 12-15 seconds until some small text appears in the top left.
Posted on Dec 12, 2012
Asus zen tablet screen is frozen and says select boot mode tried pressing volume and on button nothing how can I fix this?
press volume up and power at exact time asus screen appears. use volume up to make selection and hold volume down to select.
Aug 17, 2017 | ASUS Tablets & eReaders
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Jun 16, 2017 | ASUS Tablets & eReaders
Nothing happens when I rub my mouse keyboard on my Asus Transformer T100. How do I get it to be visible
Ok I have been thinking about your problem. How long did you actually charge your Asus Transformer?
You might need to charge it about 8 hours minimum to get it to work efficiently. Try that and see what happens.
Jan 05, 2015 | ASUS Transformer Book T100
How do i reset my asus transformer tablet''i have a blank screen will not turn on
I had a similar problem with my Asus transformer TF101b tablet. First I charged the tablet for three hours. Then while it was still connected to the power source I held down the power button for about 30 seconds. Once I let up on the power button it took about five seconds and the tablet powered on. It took about two minutes for it to boot up and finally get to the home screen.
Dec 31, 2014 | ASUS Tablets & eReaders
Why will my Asus transformer tf101 not boot up can it be fixed ?
Three possible solutions, from mild to drastic--hope one of them can help.
1) In my experience, the battery can drop below a threshold voltage quite suddenly and cause the boot-up to freeze, or not start at all. Before you do anything else, be sure it's *fully* charged by leaving the tablet switched off and plugged into the charger for at least 12 hours. Then try starting it normally. If it still doesn't start up,
2) Try holding the power button down for a long press, at least 10-15 seconds. Sometimes this is enough to kick it into action. If not, you could try the nuclear option--
3) --a hard reset, which could be achieved by pressing a straightened paper clip into a small hole (*not* the headphone socket), or by holding down the power button and pressing the volume-up or volume-down button and then following on-screen instructions (check your manual). Note that this will erase all your user data and you should back up everything first, but if you can't boot I don't see how you could accomplish this.
Aug 11, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
How to exit
Just tap ur profile and tap the scroll down menu, sign out or shutdown. Or tap power when u slide from the right side.
Mar 23, 2014 | ASUS Transformer Tf300t Tablet
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
Dec 11, 2012 | ASUS Transformer Tf300t Tablet
On a seperate tablet PC I accidentally switched to dual clone mode but television, not monitor and now neither tablet nor monitor output works and it stuck in shut down saving mode, how can I restote...
turn the pc off and turn it back on, when it boots back up hit the fn key for lcd/external monitor until it works by turning it off of course i mean hold the power button down for 8 seconds
Nov 03, 2009 | ASUS R2H Tablet PC
ASUS Transformer Tf300t Tablet Logo
126 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
