Question about Garden
Husky power washer 2600 Tried fixing starter
Husky power washer 2600 Tried fixing starter rope, well I'n the process of fixing starter rope the rewind spring popped out... I now know how to fix the starter rope but I am having trouble putting the rewind spring back in.. any help would be good. Oh also i am wondering if its possible to oder a recoil assembly part.
  • 1,807 Answers
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Posted on Aug 01, 2013
  • 202 Answers
SOURCE: I have a cub cadet snowthrower 524 (315-616E100),
OK, this is a pretty simple fix, if you have 3 hands. What happened when the rope broke is that it allowed the recoil spring to unwind. You need to take the housing off again, put the rope back inside the housing. You then need to turn the big pulley that the rope wraps onto in the same direction as it would turn when you pull the rope. You probably need to turn it 6-8 times at least. Once you get this done, you need to hold the pulley secure and feed the rope thru the housing again, put the handle back on the rope. This last step is where the 3rd hand comes in very handy! This should get you back in business.
Posted on Dec 23, 2009
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required. http://www.briggsandstratton.com/maint_repair/
Posted on Jul 21, 2010
  • 1267 Answers
SOURCE: replaced starter rope on 5.5hp
Most of the rewind applications require you to pre load the recoil with a certain amount of turns before you wrap the rope on the pulley.
Posted on Nov 30, 2010
aquaman987
  • 927 Answers
SOURCE: installed new starter rope on
The spring must be tightened when installing the cord:
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
Posted on Mar 19, 2011
kel1guy2002
  • 3740 Answers
SOURCE: mtd 31cc cultivator recoil rope
The re-coil spring is most likely broken in the housing.
Part Number is: MTD 791-613102
Parts diagram is here:
http://www.partstree.com/parts/?lc=mtd&mn=121R+21A-121R700&dn=07281000001
Image of broken part is here:
http://www.mtdparts.com/webapp/wcs/stores/servlet/parts/part-types/engine-parts/791-613102
Remove items 31, 34 and 40 of the first link to access the recoil. The spring has to be pre-wound during installation. I.e insert spring.. insert pulley.. wind spring mount pulley.
This video may be of some assistance: http://www.youtube.com/watch?v=3U_6V-1gf0Y
Thanks for choosing FixYa,
Kelly
Posted on May 26, 2011
Installing a starter rope
Remove the 3 or so screws that secure the pull rope housing to the top of the motor. Flip it upside down and it should be pretty obvious as to how to remove the spine loaded piece that the rope goes on. Thread the new rope thru the housing and wind it up on the spindle. Make sure before you put it on that the rope pulls out and retracts like it should.
Jul 30, 2016 | Homelite 6796881 308451006 Hilmore Husky...
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Husky 2600 psi pressure washer manual
It's called the recoil and you can have just the rope replaced to fix the problem
Oct 19, 2013 | Garden
Husky 2600 pressure washer with honda gcv160 engine. engine won't run with choke off.
I bought mine at Home Depot, the pump failed after about 8 hours of use then Home Depot agreed to replace it now it failed again after aabout 10 hours of use. This is a piece of crap and Home Depot should be ashamed for selling this junk. I am sure they are in with Husky and making big dollars on a crappy product. My machine is like brand new just will not work. Now the carb has to be replaced only after less than 20 hours.
JUNK Home Depot
Nov 23, 2011 | Garden
How do i connect the starter cord together on a 01450-0model # 5hp pressure washer
Rather than to try to explain how to do the job, here are a couple of youtube videos that will show you how to repair your machine. The first video explains how to remove the starter (this is mower however similar)
http://www.youtube.com/watch?v=aswe3xyqv3s&feature=related
the following video will show how in install the rope and wind it.
http://www.youtube.com/watch?v=OgJCdrnCnwg&feature=related
Good luck
Oct 23, 2011 | Honda Black Max 2600 PSI Pressure Washer
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 | Garden
The pull cord on my pressurewasher just broke How do I fix it?
Usually you have to take the shroud that contains the recoil starter assembly off to get to it. You may have to take it apart to fix the rope. If it broke on the end nearest the starter, you probably have enough rope left to reuse it. Usually they break right at the starter, due the the constant bending and rubbing. Pay attention to how it comes apart, and make sure to rewind your spring before putting the rope back on the pulley, otherwise it will not wind back up.
Apr 24, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
I have an almost brand new husky pressure washer (one of the big ones). It has been a life saver so far. just the other day it shut its self off. its gas powered so of course i checked the gas and oil....
I assum the gas and oil where ok?? did you check the pump oil?? if fluids are ok, have you tried to take the pressure off the pump by squeezing the pistol to allow water to flow and at the same time pulling the starter rope...sound as though you are fighting the compression of the water pump on the unit and in most cases this is the method to start you pressurwasher.
Please rate a Fix Ya!! Thanks I am jj505
Apr 13, 2009 | Garden
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
