Question about Irons
Safety fuse blown in Phillips GC7320 steam iron
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: my Phillips gc7320 steam iron
Hi joseph mc410
Go to HomeDepot,Lowes,WalMart,any hardware store,etc.
Purchase some "CLR" mix it according to the directions on the bottle and pour it in your iron and let it work...then pour it out, flush with distilled water and you should have cleaned your iron now.
Please take time to rate me
Posted on Sep 19, 2011
Testimonial: "thank for you help"
ercupa190
  • 12223 Answers
SOURCE: GC7320
read the steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Posted on Jul 29, 2013
My Iron keeps tripping the fuse in main power box what is causing this it doesn't happen with any other appliances?
Tripping the breaker or fuse as you call it is caused by excessive current draw. These are safety devices that are meant to protect from electrical overloads and fires. More than likely your iron has a failing heating element and should be replaced. If it is a steam iron it is also possible that it has developed an internal water leak causing a short. Continued use is unwise and a potential safety hazard.
Feb 19, 2015 | Irons
My Phillips GC8600 series steam iron has stopped steaming mid iron. None of the tips in the manual are the problem
Try running some white viniger through it. It sounds like calcium build up. This woud be especially if you are not on a soft water source.
Nov 22, 2014 | Irons
GC7320
Clean an iron:
Jul 29, 2013 | Irons
GC7320 : my appliance has been well rinsed out, but is unable to produce steam when it starts to 'pump'. What should I do, please?
see the instruction and fix it. God bless you
Clean an iron:
My Phillips gc7320 steam iron keeps spitting out brown water what is the best way to clean the chamber
Hi joseph mc410
Sep 19, 2011 | Irons
How to clean a phillips gc 8320 steam iron
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hi,<br />Here is a tip that will help you with that problem...<br /><br />Cleaning a Steam Iron Soleplate</span></div> <div class="solution-text"><span><br /><a href="http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate" target="_blank">http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate</a></span></div><span> <div class="solution-text"><br />Cleaning a Steam Iron White Scale and Brown Water</div> <div class="solution-text"></span> </div> <div class="solution-text"><span><a href="http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown">http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown</a><br />heatman101</span> </div><!-- /solution text --><!-- helpful bar -->
Aug 26, 2010 | Philips Irons
Sunbeam steam iron 4239 adjustable steam iron won't heat up
POSSIBLE CAUSES:
1. Blown fuse
2. Broken thermostat
3. Broken power cords
4. Broken heating elements
first of all check FUSE.
good luck...
Apr 06, 2009 | Sunbeam Irons
My iron doesn't steam up anymore
Time for a new iron. I last one went to the iron graveyard and I then spent $150.00 on the top of the range Phillips with the gold plate. Has cut my ironing down to a 1/4 of the time. Well worth it
Feb 02, 2008 | Micro Pro 7599 Iron
Irons Logo
29 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
