Question about Intex Easy Set Pool 15x36
Intex inflatable Hot tub leak
Intex inflatable Hot tub is leaking, person who set it up left a piece of paper with pictures and instructions on the floor and it leaked overnight, instructions were destroyed and no idea how to fix the leak around the tube connecting the pump to the tub.
4 Suggested Answers
lonewolf1996
  • 142 Answers
SOURCE: Intex Easy Set 530 Gallon swimming pool filter
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Posted on Jul 03, 2009
SOURCE: Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
Posted on May 31, 2010
  • 15 Answers
SOURCE: I have the 12'x30
YOU MIGHT CHECK THE GASKET INSIDE THE IMPELLR CASING AND MAKE SURE THE SCREWS THAT HOLD IT IN PLACE ARE TIGHT ALSO CHECK YOUR SEAL BETWEEN YOUR PUMP AND FILTER. THERE IS ALSO A LARRGE NUT UNDER THE FILTER HOUSING THAT COULD WORK LOOSE. I WOULD ALSO CHECK ALL O RINGS AND MAKE SURE THEY ARE PLIABLE AND IN GOOD SHAPE.
Posted on Jul 30, 2010
Do the heat and filter on an intex pure spa hit tub need to run continually together? I would like to put a timer on the filter.
read the manual but generally yes as if there is no flow then the heater element will over heat , boil and burn out
Mar 18, 2018 | Therapure Four Person Inflatable Round Hot...
I have just installed my intex portable hot tub but there seems to be a leak coming from the bottom.
That's unfortunate. Well, empty the hot tub, and then check the place thoroughly. Is it leaking from inside the outlet? Than check the plug in the outlet tube, if it fits correctly.
Detecting Leak in an Blow Up Hot Tub
Apr 01, 2017 | Pool & Spa
What chemicals do I need in my intex inflatable hot tub
Hi, according to this site How to Treat Your Hot Tub Best Hot Tub for 2014
First check th pH levels with the pH level checker.That is pretty straightforward and should be included in instructions with your pH checker (which may have come with your hot tub)
It's good to do a chlorine shock once you fill the hot tub with water.
So what will you need?
pH tester/pH tester strips
chlorine
And chemicals for balancing ph ... pH+ and pH- which you will surely find in a shop with pools.
Each of this should come with instructions.
Apr 09, 2016 | Intex Pool & Spa
My inflatable therapure jacuzzi tub has a leak on a seam. How do I fix it?
Seam leaks are most difficult to fix on amy inflatable product. However, if yo can find an AC man or an AC supply store that will sell to you they have a tape that is foil on one side and a thick gummy material on the other once in place it is impossible to remove. My brother called it "Hard Cast" but it is not, hard cast is a two part process that will not work for you. This tape has a paper that you must peal off before you apply it.
31644dba-35b4-49c2-9610-b86152d92ddc.jpeg Drain the tub, let it dry, no moisture or dirt or soap residue. Let all the air out of the tub. Then apply enough tape to cover the tare by 2" on all sides. Also trip the tape so that there are no sharp edges. This will not only feel more comfortable but make it harder to peal away. Make sure the tape goes on smoothly and with no wrinkles in the vinyl or the tape. You will only get one shot at this.
May 24, 2014 | Therapure Four Person Inflatable Round Hot...
Best way to locate and repair a slow leak in a intex seahawk 500 inflatable
Get some bubble bath, mr. bubble, or just dish soap, thinned out with water, spray it all over the boat, you will get it cleaned up and find the leak at the same time. When you see th e stream of bubbles coming out, mark it, get it dried off and patch it up. I think they use a contac cement on the Hypolon boats, or is it neoprene? Do you have a patch kit? Any pieces of material for a patch? The hardware store has pvc rubber used for shower pans, that might stick on there, clean it good with laq thinner, and brush on some glue, both pieces, let dry, then slap them together. You will know if it will work. Or else look up the manufacturers recommendations. he boat supply might have patch kits in stock. Hope this helps.
Jun 24, 2010 | Intex Excursion 4 Inflatable Boat Set
The tube around my intex pool has a leak, how do I find it and fix it?
Your picture above is of a pool float, but I assume you are talking about an inflatable ring pool. Is that right? If so, this link will take you through a tutorial on how to find and repair pool leaks:
http://www.backyardcitypools.com/vinyl-pool-liners/Swimming-Pool-Leaks.htm
Jun 20, 2010 | Creek 4 River Run Inflatable Inner Tube ...
Our Intex air bed has a leak, we think the leak is in the valve. over night the bed deflates, ugh.
Guerilla repair it by replacing the valve by cutting out the valve add a new valve with extra rubber and, rubber cement.
Dec 22, 2009 | Intex AIRHEAD Performance 1-Person...
Intex Easy Set Pool 15x36 Logo
617 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
