SOURCE: Honda CBR 900rr 95 Will not start
Check fuel pump is working(remove seat and tank)Although your bike has carbs,they are fed by a fuel pump(under seat and tank)
if there is no fuel getting pumped when you are cranking over,replace fuel pump relay(cheapest option)If still no joy your fuel pump is u/s.although hondas have a seperate small vacume type hose running off the back of the pump,any pump off a kawasaki zx7/zx9 will do the job(they are all made by the same firm)
SOURCE: 95 Honda CBR 900 rr will not start.
Definatly a good tune up would help, but it also sounds as if you may have a bad stator. I would check the voltage at the battery and see if it goes up and down when accelorating.
SOURCE: cbr 125 choke problem
It sounds like the choke line may not have been routed correctly when the new one was installed. Remove the gas tank and check to see that the line is not being stretched anywhere along the way AND that the gas tank when re-installed is not stretching the line. The line may have been kinked when installed. Look at the mechanical movement of the choke at the carb. Does it operate freely? Remove the air filter and look inside the center of the carb, (you may need to use a small mirror for this), does it look like the choke is opening and closing properly when the choke is moved on and off?
SOURCE: 2002 cbr 954 red light on gauge blinks
sounds like the engine management fault code signal. there is a free download service manual here. with it you should be able to decifer it http://www.carlsalter.com/motorcycle-manuals.asp
Headlights and, starter motors require more amps (power) than the blinkers and, taillights
so: jump your battery before you tear into the wiring
If it still doesn't start or, light up
I'll help you troubleshoot the wiring
