Question about JBL Audio Players & Recorders
Circuit diagram subwoofer jbl sub150p - JBL Audio Players & Recorders
What i ca i do my jbl bulse burnt?
There should be a short circuit inside its circuit board. You have to check the audio output circuit to get the fault, and to replace the damaged component/s. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Circuit diagrams of SMPS & power amplifier to many models of JBL sets are given.
Jun 27, 2016 | JBL Audio Players & Recorders
Wireing diagrams for a pair of 12" jbl gt1200D grandtouring subwoofers JBL Grand Touring Series GTO1200D 12" subwoofer with dual 4-ohm voice coils
Check crutch fields website for sub wiring it's really straight forward depending on the desired impedance.
Oct 09, 2014 | Car Audio & Video
Jbl jrx 100 popping
Check all electrolytic capacitors on the amp circuit board.
Jun 05, 2012 | JBL JRX-118SP Subwoofer
How and where can I get a circuit board for jbl venue sub 10
There is a guy on Ebay who repairs these - not sure but I don't think the board is available - you could check with Harmon - they own Infinity and JBL
Aug 18, 2011 | JBL Venue SUB10 Subwoofer
The fuse keeps blowing as soon as i power up jbl pb 12
You have an overload in the power supply or main amp of the subwoofer, often caused by short circuited transistor. Check this out by putting an ohm meter probe to each of it's legs. If it acts like you were touching the probes together you have found a guilty part.
Jan 10, 2010 | JBL PB12 Subwoofer
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
Bloon Fuses!
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
Aug 18, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
83 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
