Question about bookslib A Career Girls Guide to Becoming a Stepmom: Expert Advice from Other Stepmoms on How to Juggle Your Job, Your Marriage, and Your New Stepkids
I am bored i don know what to do - bookslib A Career Girls Guide to Becoming a Stepmom: Expert Advice from Other Stepmoms on How to Juggle Your Job, Your Marriage, and Your New Stepkids
Standard bore size mm
ENGINE 2 stroke single cylinder direct reed valve crankcase induction Liquid cooled 125 cc engine Cylinder size 124 8 cc Bore and stroke 54 x 54 5 mm 200 cc engine Cylinder size 175 3 cc Bore and stroke 64 x 54 5 mm 250 cc engine Cylinder size 247 7 cc Bore and stroke 72 5 x 60 mm 280 cc engine Cylinder size 272 2 cc Bore and stroke 76 x 60 mm 300 cc engine Cylinder size 294 1 cc Bore and stroke 79 x 60 mm I Cant put periods or commas so bare with me
Mar 15, 2014 | 1999 Daewoo Lanos
2003pontiac grand prix how compress the piston by compressing or by turn in ?
What you need to do is lift the car take out the wheel where crank shaft is,
also know as the harmonic balancer
Jan 20, 2013 | 2003 Pontiac Grand Prix
I have a 82 ford f 100 and the front pads won't
Do they have spring clips holding them fast to the caliper. Just pry them off the caliper with a screwdriver. The outer pad that rests against the caliper piston bore also has a clip underneath going into the bore. It is also just pulled out. Maybe a little rust is holding yours tighter than normal? You do have the caliper bolts removed, and the caliper free from the rotor, only held to vehicle by the brake line, right?
Good luck.
Jan 29, 2012 | 1981 Ford F 100
Dear Sir, can a gl1000 be re,bored & fitted with
Yes it can be bored, .050 over is fairly common on this bike. Before boring the cylinders, the new pistons should always be matched to the old ones. You always find problems with aftermarket parts. Have the cylinders bored to match the new pistons. Don't bore the cylinders and expect the new pistons to be a perfect match. I hope this helps.
Jul 03, 2011 | 1976 Honda GL 1000 (K1)
2004 fatboy was bored out to 110 and I don't know why my thunder header is turning yellow
You're probably running lean. You need to have the bike run up on a dynometer with an exhaust gas analyzer to determine what the mixture is and have it changed.
Good Luck
Steve
May 12, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
I need to know the center bore on my mini 1275 clubman its the old one not the new one
What do you mean by "center bore"
Bore X stroke on the old Clubman 1275cc (Engine codes 12A and 12 H) is 70.61mm X 81.28mm
Sep 23, 2010 | Mini Cooper Clubman Cars & Trucks
Turn on laptop. within minutes fan is running full bore and bottom is very hot
is this a new laptop? if not it may be that the fan needs a clean and new thermal compound needs to put on the cpu. if it within warranty i would contact compaq. You can do it yourself if you know what your doing but if you don@t then please don't try it as involves know how and if you mess it up you could have a dead laptop @ the end.
www.pctechguyonline.com
Feb 02, 2010 | Compaq Presario F730US Notebook
87 yz 125t. bored .30'' over need 56.75mm Piston
yea, for most bikes they only come in .020 increments now. if your looking to freshen up the top end, then youll have to go to a 56.00mm piston. there will be almost no change in displacement or jetting from 55 to 56mm. if your replacing the piston, its best to have your cylinder bored anyways. since the worn cylinder walls may have adverse effects on the new piston rings, and they may wear a bit prematurely. a bore only costs about 30-40 bucks most places, and its cheap insurance. plus you will have the peace of mind knowing that your bore is matched specifically for your piston. I would definitely recommend a fresh bore.
Jul 29, 2009 | Yamaha YZ 125 Motorcycles
Throttle bore
your throttle bore is the hole opening at the begining of your intkae manifold, follow the large hoses from your air filter toward the engine, where the hose stops is the throttle bore. It should be about 3-4 inches in diameter, hope this helps, let me know
May 26, 2009 | 2004 Dodge Ram 1500
bookslib A Career Girls Guide to Becoming a Stepmom: Expert Advice from Other Stepmoms on How to Juggle Your Job, Your Marriage, and Your New Stepkids Logo
529 people viewed this question
Top bookslib Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a bookslib Craft and Hobby Expert? Answer questions, earn points and help others
