Question about Frigidaire GLTF2940ES Front Load Washer
Repair manual it doesn't spin. we plugged it in but didn't connect the water and tried to turn it on to see if it spun but it did not. what should we do?
  • Official Brand Answer
  • 4,342 Answers
Hello William, I highly recommended to fully installed and connect the washer properly to accurately determine if the unit will spin or not. Once that is done, and the issue persists, often it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Posted on Aug 02, 2013
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
Admiral washer will not spin but does agitate.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely -if it's frozen or stiff- replace it.
a.- It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
a.1. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
a.2. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.- It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
b.1. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.2 The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
b.3 A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
b.4 The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
b.5 The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
b.6 The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
b.7 The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
c.- It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Additional details in Admiral: Washer Use and Care Guide (PDF Format)
Check it and keep us updated.
Oct 10, 2011 | Admiral AW22 Top Load Washer
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
Close the washer and press the START/PAUSE/Cancelbutton to remove error displayed and restart the cycle. If it doesn't work, it means thatthe valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens Washing Machines
Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle. If it doesn't work, it means that the valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens WFXD8400UC Front Load Washer
Model GLTF167A0S0 Serial XC22704657... The final spin frequently doesn't work. I tried another wash cycle and the "high speed" spin didn't work. I can manually start the cycle and it...
If the water is pumping out fine you may need new shocks. But if it is slow pump the shaft on the pump is loose and causing the noise and possibly the spin issue. If it is loud when it does go into a spin (sounds like a jet engine) you have bad bearings. Big bucks to fix.
Jun 03, 2011 | Frigidaire GLTF1670A Front Load Washer
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Frigidaire GLTF2940ES Front Load Washer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
