Question about Avaya Lucent Ks-23395l4 Moh Music On Hold Coupler
What type of cable connects to a lucent KS-23395L4?
Knock sensor for 2007 Saturn outlook. I can't pass emissions test!
Check engine light on ? What code ? There are many different (DTC'S) - diagnostic trouble codes that can set for knock sensors ! There all don't mean that you replace the sensor .
DTC P0324: Knock Sensor (KS) Module Performance
DTC P0325: Knock Sensor (KS) Circuit Bank 1
DTC P0326: Knock Sensor (KS) Performance
DTC P0327: Knock Sensor (KS) Circuit Low Bank 1
DTC P0328: Knock Sensor (KS) Circuit High Bank 1
DTC P0330: Knock Sensor (KS) Circuit Bank 2
DTC P0332: Knock Sensor (KS) Circuit Low Bank 2
DTC P0333: Knock Sensor (KS) Circuit High Bank 2
The knock sensor (KS) system enables the control module to control the ignition timing for the best possible performance while protecting the engine from potentially damaging levels of detonation. The sensors are located below each cylinder head on the engine block. The KS produces an AC voltage signal that varies depending on the vibration level during engine operation. The control module adjusts the spark timing based on the amplitude and the frequency of the KS signal. The control module receives the KS signal through 2 isolated signal circuits. The control module learns a minimum KS noise level at idle and uses calibrated values for the rest of the RPM range. The control module should monitor a normal KS signal within the noise channel.
Knock Sensor Replacement - Bank 1
Remove the exhaust manifold lower heat shield. Refer to Exhaust Manifold Lower Heat Shield Replacement.
Disconnect the engine wiring harness electrical connector (1) from the bank 1 knock sensor (2).
Loosen the knock sensor bolt and remove the knock sensor.
Knock Sensor Replacement - Bank 2
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Remove the engine oil filter. Refer to Engine Oil and Oil Filter Replacement .
Lower the vehicle.
Disconnect the engine wiring harness electrical connector (2) from the bank 2 knock sensor (3).
Nov 12, 2016 | Saturn Cars & Trucks
How do I fix code PO327 Knock Sensor 1 Circuit Low Imput Bank 1.
code p 0327 refers to knock sensor (KS) 1 bank 1---low input===causes ---insecure KS, poor connection---wiring short to ground---incorrectly tightened---KS---ECM
check all the wires for good connections and the fitment of the KS
replace the KS if all other items check out ok
Dec 14, 2015 | 2004 Infiniti G35 Sport Coupe
My HP ENVY printer will not install.
Hi Steve,
The Lucent Win Modem is hardware on your computer and if that has failed then that could be causing a problem during the installation if it can't connect to the printer. What is your product number? Use this link to find it: http://h10025.www1.hp.com/ewfrf/wc/findModel?lc=en&dlc=en&cc=ca&lang=en
Which type of printer cable did you use an Ethernet cable or a USB cable?
You can also try using the HP Print and Scan Doctor as well. Download and run that and it should be able to tell you the problem and it might even fix it for you.
http://support.hp.com/us-en/document/c02073861
Thank you,
BHK6
I work on behalf of HP.
Apr 23, 2015 | HP Computers & Internet
I have an lucent technologies modem (an soft modem AMR) on my laptop ive been searching all day for the driver but i cant find the right driver and i checked everywhere
This is for your modem for windows: Just below click the link and type the validate code then below that click on download. You have to type in the code to prevent spammers from overloading their website.
http://www.opendrivers.com/driver/213151/lucent-agere-ltwin-modem-pci-isa-8.30-for-windows-free-download.html
Jan 02, 2010 | Lucent (71210) Modem
Diagram for adaptor ks-u57
There's nothing to it--look 'inside' the connector and you'll see three metal contacts close the metal connector (somewhat similar design as a USB jack). The center is common for the line out, and the left/right are the positive for the left and right channels. The metal connector itself is not part of the circuit.
So if you were connecting RCA jacks to it, the outer ('negative') of both RCAs connects to the center contact on the KS-U57, and the center ('positive,' or 'signal') of the left and right RCAs go to the contacts bracketing the center.
KS-U58 and KS-U57 are wired the same.
Oct 31, 2009 | JVC Ks U57 Line In Adapter
What is a Lucent Pipeline P130-u-v35-asa used for
The short answer is.... It is a T-1 Router/Firewall that works with ISDN and Frame Relay. It uses the V.35 and BRI interfaces and requires an external CSU/DSU. It is NOT compatable with Cable or DSL internet service providers.
Oct 29, 2009 | Lucent Pipeline 130 Router
What is Lucent 7 Cabling?
Lucent 7 cabling *probably* refers to level 7 Lucent cable. It's old!! There are two issues in the question of, "What is Lucent 7 cable?" Here's the history: Lucent was a division spun off by AT&T back in the mid 1990's. Then Lucent actually spun off Avaya and sent their structured cabling business with it (they had named the cabling brand "Systimax" by that time. CommScope bought Avaya back in 2004, so Lucent's Systimax brand of cabling is 2 generations out dated. It's still probably okay, but not worth today's money for new Systimax products made by CommScope.
Now for the 7 issue: there was no talk of category 7 (cat 7) back when Lucent was making cable, but Anixter, a data cable distributor, rates cabling with their own proprietary system called "Levels". Therefore, Level 7 cabling is an Anixter measure and many people have bought from Anixter long enough that they ask for level 7 [brand whatever] cable.
Use it if it's low cost. Otherwise, don't let someone sell Lucent branded-cable as the same as today's cable. There were version upgrades since then. The print on the cable jacket will say 1071C or 2071C or something like that. Today, they are on version E, not C.
Hope it's kind of clear. My guess is the cable is about 10 years old, although some data folks are stuck in their ways and still refer to today's Systimax cable as Lucent cable.
Apr 14, 2009 | Lucent Computers & Internet
KS-U58 JVC Input Adapter Cable
Just installed a 'generic' KS-U57 (same as the KS-U58, but terminates in a RCA, $7 on ebay) that has the same black box--except I cracked the black box open and found that it is empty (only contains soldered connections). I imagine that the authentic JVC is the same.
I have a noise problem (engine static), but it is because my mp3 player is charged by the cigarette lighter--unplugging it eliminates the noise, so as far as I can tell, there is no need for a noise filter inside the KS-U57.
Dec 04, 2008 | JVC Ks-U58 Input Adapter To Stereo Mini...
Lost the conector jvc ks f 150
Go to JVC website and type in your Model # and get the Installation/Connection Manual for free. This installation guide includes troubleshooting, electrical connections, and adding other equipment. Hope this is helpful just printed me a copy.
Nov 16, 2008 | JVC KS-F150 Cassette Player
Avaya Lucent Ks-23395l4 Moh Music On Hold Coupler Logo
42 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
