Question about Panasonic Toughbook CF-29 Notebook
Cf-29 wont start - Panasonic Toughbook CF-29 Notebook
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Touch screen doesnt work on my cf-29
    Hi Jade. If you have a windows XP in your machine Try to upgrade to win7 or win 8 since windows xp doesn't come with touch screen drivers.
    Jan 23, 2014 | Panasonic CF-29 (CF29NWQGZBM) PC Notebook
    ATV mounted CF 29 in Big Red cab blown motherbroad
    If your antenna is not grounded correctly as well as your PC power, you may be getting a loop of voltage through your controller interface trashing your motherboard.
    Jan 17, 2014 | Panasonic Toughbook 29 Touch (P/N...
    How do you obtain the hard drive serial numbers for CF-30 and CF-31
    Try this freeware program, SPECCY at: http://filehippo.com/search?q=speccy Install and start, look at the HARD DRIVE section. You will find useful info to ID your Laptop's hardware/software OS.
    Aug 24, 2013 | Panasonic Toughbook CF-29 Notebook
    Cf-29 replace mouse pad
    Panasonic Toughbook CF-29 series of Notebook PC's, Service Manual,
    http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-panasonic
    Go to the line that starts with CF-29N3LGZBM, and CF-29NTQGZBM
    For the CF-29N3LGZBM the disassembly starts on Page 19, and for the CF-29NTQGZBM.
    I don't see the difference, but perhaps you will between the two.
    To me a CF-29 is a CF-29
    You disassemble from the Bottom up. Remove Base Enclosure,
    http://www.youtube.com/watch?v=-ITIcLckkIw
    (No narration, just 'elevator' music)
    Remove Mousepad,
    http://www.youtube.com/watch?NR=1&v=8BJRwBwCKhg&feature=endscreen
    A) Remove ALL power. Remove the AC adapter (Charger), and Battery
    B) USE an ESD wrist strap, and have it's alligator clip attached to a good ground source.
    (Electro Static Discharge)
    Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
    Wear an ESD wrist strap, and your laptop is safe from Static.
    (From you)
    Don't wear one, and use your laptop for an expensive paperweight.
    Average cost is $3 to $6. This is but one example,
    http://www.radioshack.com/product/index.jsp?productId=2103245
    I connect to an unpainted surface, of an empty open desktop computer case. (I don't feel an Anti-Static Mat is warranted, and can explain)
    You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
    Or perhaps a large metal knickknack. (Unpainted)
    You can't discharge Static by touching the metal frame, of the laptop.
    Doesn't work that way. (ZZZZZzzzzap! Goodbye computer )
    C) Use a multi-compartment container for the various screws you will remove.
    Label each compartment for the area the screw/s come out of.
    SOME screws look VERY similar to other screws!
    Advise do NOT mix them up.
    D) Take photos, or use a video cam; if available. Use good lighting.
    Make notes, and/or drawings if you wish.
    It's nice to have a Personal record, as well as a Service Manual, and pictorial information.
    It's nicer to have YOUR method YOU used, along with the above.
    Jus sayin'.
    No.1 Philips screwdriver
    Put everything back just LIKE it came out. Don't pinch any cables.
    http://www.bobjohnson.com/_store/Display_Buy.asp?prodID=CF29MOUSEBOARD
    http://www.ebay.com/itm/Panasonic-Toughbook-CF-28-Touchpad-Palmrest-/290787254286?pt=LH_DefaultDomain_0&hash=item43b445600e
    http://www.ebay.com/sch/sis.html?_nkw=Panasonic%20Toughbook%20CF%2029%20Pentium%20M%201%2030Ghz%20512%20MB&_itemId=151000412795
    Wow! Sellin' kinda cheap! Looking for parts I ran into this.
    Not advertising. Besides, it isn't allowed on here anyway, lol!
    For additional questions please post in a Comment.
    Regards,
    joecoolvette
    Feb 22, 2013 | Panasonic Toughbook CF-29 Notebook
    Where is the fuse to the panasonic cf 29 laptop
    Here is the service manual for it. This should help
    http://www.scribd.com/doc/52162841/panasonic-CF-29-SM
    Sep 02, 2012 | Panasonic Toughbook 29 Touch (P/N...
    I require LAN drivers for my panasonic cf-29
    This depends on the specific model number:
    CF-29C/D -- Realtek RTL8139DL 10/100
    CF-29E/F -- Realtek RTL8139DL 10/100
    CF-29H/J -- Realtek RTL8139DL 10/100
    CF-29L/M -- Marvel Yukon 88E8053 10/100/1000
    CF-29N/P -- Marvel Yukon 88E8053 10/100/1000
    Dec 28, 2010 | Panasonic Toughbook CF-29 Notebook
    When I turn on my CF-29 it goes straight to a
    Have you tried hooking up an external monitor? If you hook it up and see video on that it's a screen issue. If you hook it up and it does the same white thing it's bad video on the motherboard.
    May 04, 2010 | Panasonic Toughbook CF-29 Notebook
    My Cf 29 wont read from the cd drive... just hear a scratching noise and it won't load
    how long have you been using this player? The problem should be from the lens (laser).
    The lens is weak and that's why it cannot read/load Cd's.
    Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole drive completely to a brand new one.
    By so doing your player would play all Cd's with no problem at all.
    Good luck.
    Apr 21, 2010 | Panasonic CF-VCD271 CD-ROM CF-27 CF-28...
    When i turn the cf-29 on i get the panasonic boot screen then it goes blank
    Your boot loader is corrupted try reinstalling with the WINDOWS installer CD
    Or Reformat your operating system
    Thanks. Cheers!
    Apr 15, 2010 | Panasonic Toughbook 29 Touch (P/N...
    Panasonic Toughbook CF-29 Notebook Logo
    20 people viewed this question
    Top Panasonic Computers & Internet Experts
    micky dee
    Computer Repairing
    Computer Repairing
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
