Question about Homedics SC-405 Glass Digital Scale Silver
How do i reset my scale - Homedics SC-405 Glass Digital Scale Silver
My scale is a taylor 5751 bc how do i reset all memories?
Easy way is to remove the battery. Or individually;
Press and hold the "Power" button in the center of the scale. Your scale will then list the information you have saved for each memory number.
Hold both the "Up" and "Down" buttons for about three seconds. This will clear the information for that memory number.
Repeat the process for each memory number that has information stored on it.
Remove the battery from the scale. Leave it out for five minutes. Reinsert the battery to finish resetting your scale.
https://healthfully.com/reset-taylor-scale-5033705.html
Oct 05, 2017 | Taylor Health & Beauty
How do I reset the scale?
If the scale is an electronic version, remove the batteries and wait a minute or two before replacing the batteries. That will probably zero the scale. If that doesn't work, it's time to buy new batteries.
Jan 13, 2015 | Health & Beauty
I have a NOVA Weighing Scale model BGS-1212. I am not able to reset the weighing scale display. Please help
i HAVE NOVA ELECTRONIC PERSONAL GLASS SCALE MODEL BGS-1212. THE RUBBER GROMET STAND IS CRACKED. I HAVE TO REPLACE THE SAME PLEASE INFORM ME THE REPARI CENTER NO.
Oct 14, 2012 | Health & Beauty
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Resetting the scale to 0
mcdevito75 here, There should be some sort of knob or screw near the weight indicator too reset the indicator to zero. Make this adjustment without any weight on the scale.
Jun 23, 2010 | Terraillon TFA Nautic Body Fat Scale
Need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Nothing will display on the read out
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Aug 25, 2009 | Health & Beauty
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Homedics SC-405 Glass Digital Scale Silver Logo
62 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
