Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Frigidaire Gallery Model GLTF2940ES2 front load washer. Drum won't turn. The door will lock and it will start to fill with water but instead of the drum turning the front control panel will only hum. The belt is okay and I think the motor is okay. Could it be a relay switch is bad?
4 Suggested Answers
  • 3741 Answers
SOURCE: Washer will not spin for
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jul 11, 2009
SOURCE: frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Posted on Dec 06, 2009
dr appliance
  • 266 Answers
SOURCE: Frigidaire GLTF2940ES0 front load washer. turn it
does it ever agitate ... if it does than the door is locked ...there is a magnet that falls off these machines the detergent dispensor that tell the washer control board that the detergent dispensor is closed so water wont spray out if left open ,,,,magnet rectangle and size of a pencil rectangle shape .... you can try putting a large size magnet on the opening of dispesor shroud ,,,, usually when you replace the control board they have removed the magnetic dispensor reed switch and just jumped across the board eleminating this connection.
Posted on Jan 31, 2011
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
My Frigidaire model no LTF2940FSI will not fill with water...any suggestions?
The unit needs to sense the door lock before allowing to fill,start unit and listen for the door lock system, if the lack fail to either sense the door or the prongs on the door are broken, this will happen.
Part number for door lock 131763202 Part number for door striker 131763310
I hope this helps...
Jul 11, 2011 | Frigidaire GLTF2940ES Front Load Washer
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
Cant open frigidaire gallery washing machine door
Hi.... if you can't open your door you have something in your drain pump or you need a new pump ... If your washer can't drain the water out yoru washer will lock you out ... till the water is gone
Mar 24, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My Frigidaire front load washer doesn't spin, it turns during the wash cycle, doesn't show an error code, but doesn't spin the load at all, it is model CLTF2940ES0. Is it something simplet to fix?
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
Sep 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
OK I have a frigidaire front load washer model #GLTF2940ES0 it won't start but the lights are on. I push the button and it blinks err then lock. what can I do?
hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer will not start cycle
and hi again,
Saw the review and the rating. Appreciate the kind words and glad to be of assistance.
Cheers.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
