At irregular intervals, sometimes two or three times a day, sometimes after two or three days, water pours out the square hole below the freezer and soaks things on the shelves before collecting in the trays and pan in the lower compartment. The gaskets all seem perfectly fine.
Every ten to twelve hours or more irregular intervals if equipped with an adaptive defrost control your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-25oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
