I have a Dual LE32PVR0801 32 inch TV. I left it on stand-by (as usual)a couple of nights ago and now when i switch it on the egg timer stays on the screen as if the hard disk is warming up and wont switch to the freeview. What can i do? I tried turning it off for a minute putting it in stand by for a minute and then switching it on but it doesnt work!
SOURCE: TV refuses to stay on
I'm the OP of this, and what I did was had it unplugged for about 2 days, plugged it back in and it has worked since.
Posted on Nov 10, 2007
Agent Aaron
  • 265 Answers
SOURCE: all TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
tvguy171
  • 106 Answers
SOURCE: Samsung HL-r5667w TV shuts down on its own.
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Posted on Dec 16, 2008
  • 700 Answers
SOURCE: tv switching on from stand by
It could be not inputing any number on the timer. Or sometimes hitting the button many times until you get it to zero setting. Or sometimes, the cheat of not setting the time clock of the tv.
Posted on Apr 22, 2009
SOURCE: Samsung DLP 62 inch turns off by itself after being switched on
take off the lamp access door on the back and find the safety switch that the door pushes on. unplug the connector from the switch and put staple into the connector to short out the cable. Switch is probably bad. worked for me. same problem.
Posted on Apr 28, 2009
Turn off night lights and have no lights on during the night
The blue lights imitate moonlight over the ocean. Those lights are there to better imitate the fish's natural environment, which is almost never completely dark.
Feb 14, 2014 | Oceanic Coralife Digital Power Center -...
Samsung 50 inch plasma switches on in the middle of the night
Check the remote button said SLEEP in not on.Like it on a timer like 30,60,120 mins,turn it all off.Ur tv might be setting on a timer setup,check ur tv menu too.
Mar 18, 2011 | Televison & Video
Keypad is not working. Went into sabbath mode by itself once. Beeped all night a couple of nights ago. Timer will not work and can not set the clock. Need to shut power off for awhile so I can use the...
We have the same problem! We cannot find the manual, but the manual to a similar oven says to hold the reset button for 5 seconds. We do not have a reset button, so we are stumped.
Jul 27, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Dec 16, 2008 | Samsung HL-R5667W 56" HDTV
19 inch lcd tv with dvd
Check to see it maby the tv is set to
to timer operation and also try to reset the the tv functions
Loumargo
allied \electronics
Jan 01, 2008 | Televison & Video
Tv went blank
Does the timer/stand-by light blink at all? If so, count how many times it does. It will usually be in intervals. If it isn't blinking, and you have nothing on the screen, you might have a problem with the "G" Board, part # A1316499A.
C-Dog
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
STANDBY BUTTON
call 1-800-256-2487 they will help (maybe)
Dec 10, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
