Question about Danby DBC514BLS Silhouette Beverage Centre
How do I replace the sensor in my Danby Beverage Cooler? I have the part and located it on the inside of the unit but the wires go from the sensor to the back of the unit and the back of the unit is sealed. How do you access the wires behind the back exterior panel?
4 Suggested Answers
  • 4 Answers
SOURCE: Temp wont go below 60
Very simple. Call Danby at 1-800-26-DANBY and tell them the issues you are having. The reps there are very knowledgable and more than willing to help. I just had to replace a computer pad and they are awesome to deal with. FYI, the owner's manual does not have a parts listing. Good luck
Posted on Jun 15, 2009
  • 4 Answers
SOURCE: inside fan on Keg Cooler needs to be replaced
Call them and ask to buy the part it should be pretty cheap. I just bought a replacement keypad for mine and they sold it to me right on the phone no hassles
Posted on Aug 07, 2009
  • 132 Answers
SOURCE: The fan on our Danby
You will need a new fan motor.
A technician can fix that for about $250
Posted on Mar 25, 2011
I purchased this product a month ago and it is now leaking oil on the inside Any suggestions??
return IT ASAP. THIS COULD BE A SIGN OF A EVAPORATOR LEAK. And the unit will soon fail.
Sep 18, 2015 | Danby DBC120BLS Free Standing Wine Cooler...
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Inside fan on Keg Cooler needs to be replaced
Jul 23, 2009 | Danby DKC645BLS Compact Beverage Cooler
E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Nov 17, 2008 | Refrigerators
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
Buzzing noise from DKC645BLS
It's the fan that moves the air around inside to aid in circulation. Call danby and ask to buy it. It shpuldn't be very expensive at all.
1-800-263-2629
Jul 11, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby Keg cooler
Let me know if you need anything else, I'm replying so this message will come off my profile. Thanks, glad too help.
Jul 07, 2008 | Danby DKC645BLS Compact Beverage Cooler
Thermostat
It's the Danby "auto-defrost" feature. It cycles off every 24 hrs to defrost, at which time the temp rises (as the unit isn't running!). Not much you can do. By the way, the blue LED temp display isn't accurate. It NEVER gets 36 (liquid temp) inside the Danby unless you do the following: Open the door and look to the back left. There is a small grate covering the temp sensor. Remove the grate and place the sensor into a small cup of water. The sensor will now read the "liquid" temp inside the keg, and not the "air" temp. The Danby will then cool the inside to a more beer friendly temp, and should not only cut back on foam, but taste better.
Sep 03, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DBC514BLS Silhouette Beverage Centre Logo
82 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
