Question about Aqua Ultraviolet Aqua UV Classic - 40 Watt Clarifier/Sterilizer - White
I need help wiring a 40watt raw transformer to classic aqua uv device.
Hampton bay fan 40watt bulbs barely come on
Are you just using pull chains for fan & light?
Oct 20, 2015 | Hampton Bay Dryers
Where can i buy a replacement transformer for a FISH MATE 15000 11 watt UV ?
You can use a different manufacturer with different numbers. All that matters is that it is for a 11 watt fluorescent bulb. UV does not matter to the transformer. Here is one site; http://www.buylightfixtures.com/ballasts-and-transformers-1.aspx
Oct 09, 2014 | Garden
File system lost?
I recommend SpinRite from grc.com. It is the most diligent utility I have used for this. Explore and understand the explanation of what it does on the website.
Jan 12, 2014 | ADATA 1TB Classic CH11 Black External Hard...
1997 kawaski vn 1500 Vulcan classic d raw fuel down needle value of carb
sounds like carb, is airfilter set up ok, it can act as an air restrictor to match the jetting
Feb 16, 2013 | 1999 kawasaki VN 1500 Vulcan Classic
My Orbit 57899 is saying no ac but the outlet to where this goes is working fine
I believe that you plug a transformer into the outlet. If this transformer is not working, no power goes to the timer. Remove the battery and if the timer display goes out (and it may take some time, possibly hours) the transformer is in need of replacement. They are available at sprinkler suppliers and maybe even a local hardware.
Gary
Jul 03, 2011 | Orbit Sprinkler System Power Source...
Can't find uv lamp in Fresh Air by ecoquest
The picture is a classic, with no UV light. Still works great. It got my kids off their inhalers after 15 years of 4 per month. Now 4 per year. A Fresh Air, depending on the age, has a light attached in the bottom of the visible base behind a cage and plate, and the new honeycomb units have the light inside the honeycomb.
Jun 22, 2011 | Ecoquest Living Air Classic Air Purifier
My aquagard is probling from 2 months the red light is blink when we start aqua iam tired to complaining many times to service centre from where i did emi
The red light comes on due to a failure to detect the right intensity of light into the controller board. The LDR- light dependentt resistor - is fixed on to the cylinder which has the UV light. Hence the unit is clogged and the light intensity has dropped. You will need to open , clean and reset for the fault to go .Please take the top cover, the glass tubings and the UV lamp out very carefully not to damage.
If the fault is still persisting then the main board is faulty, sometimes the driver transistors are defective and will not output the voltage to the lamps. Please check this out and I am sure it will work. The service centres normally replace boards even if a transistor is faulty.... so your are right.
I hope my advice helps.
Aug 19, 2010 | Microwave Ovens
Where do I hook up the 24V wires for ultravation uv lamp
If this is an ultraviolet light that mounts in the furnace, then it would be connected to a transformer on the furnace. In doing this, make sure that the transformer can handle the additional load. Hope this helps.
May 14, 2010 | Air Purifiers
I HAVE A RAINSOFT UV AIR FILTER IN MY AIR DUCT WHERE DO I GET REPLACEMENT BULBS, AND WHAT IS THE PROPER BULB AND SIZE?
Cleanwater also has them. Clean them with rubbing alcohol, do not let your fingers touch the bulbs. And check your 24V ac adapter. If it starts going you will get a power light but the other lights will come and go. I have one and the bulbs are nearing the end of life, not a cheap fix.
http://www.cleanwaterstore.com/O1002250-p-clearwater-tech-parts.html
Jan 02, 2010 | Air Purifiers
Aqua Ultraviolet Aqua UV Classic - 40 Watt Clarifier/Sterilizer - White Logo
93 people viewed this question
Top Aqua Ultraviolet Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you an Aqua Ultraviolet Fish Expert? Answer questions, earn points and help others
