Hi I am a technician. The stereo set model no is HCD-GNZ 55D . The fault is when I on the power it gets on but after few minutes it automatically goes to the standby mode. Please give me a solution to solve this . Thanks
  • 356 Answers
I suspect that the capacitors in the power supply are faulty. Unplug it, open it up and look for burst caps. There was a bad batch of capacitors sold during the years that your device was made and it is easily repairable if you are able to get new caps and have some soldering skills.
Be careful, I am not liable for any mishaps as a result of you using this advice.
Posted on Oct 19, 2013
4 Suggested Answers
  • 26 Answers
SOURCE: My left speaker to my Sony HCD-GX450 stereo is
Make sure that Loudness switch is turned off & bass is not boasted up. Most cars have small cheap speakers that can't handle the bass. also its better to cut the low frequency from the woofer using a passive or active crossover. Most nowadays head units have got some sort of built in crossover. Refer to your head unit manual.
Posted on Sep 20, 2009
SOURCE: my sony mini hi-fi component model HCD-RV7, stereo wont come out
how can i remove push power protect
Posted on Oct 03, 2009
  • 6771 Answers
SOURCE: hcd-eh15
The laser pickup assembly has a short causing the unit to shut down, The whole assembly would need to be replaced in order to resolve, not worth the cost to repair, cheaper to replace.
Posted on Apr 26, 2012
I have hcd-gzr88d sony brand hifi stereo.it goes on for 3seconds and off to standby mode.what could be the problem
Audio output section circuit fault. Probably, due to the shorted output IC STK xxxx. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 13, 2017 | Sony Audio Players & Recorders
Videocon tv few minutes automatic off and few minutes on
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jun 21, 2015 | Televison & Video
PHILIPS lcd 32PFL5306/V7 is showing double image after working fine for 2-5 mins when powered on?
Hi
Look likes panel fault indeed. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 20, 2015 | Philips Televison & Video
I have a Sony Trinitron TV model number KV27S66. This morning I turned it on, it worked for a few seconds then the picture became a vertical rainbow and then the TV shut itself off. After unplugging i
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 14, 2014 | Sony Trinitron Stereo Kv-27s66 27 Inch...
Sony hcd vx55
Hello. I downloaded the manual for the Sony system with the model number MHC-VX55. It seems that the part you are asking about is not a speaker system, but a preamplifie/power amplifier with integrated inputs from CD/Video, tape and tuner. The speakers that connect to the HCD-VX55 are a three way passive design with a nominal impedance of 6 ohms and model number SS-VX55. To answer your question I will assume that you meant you would like to connect the MHC-VX55 system to your computer for playing back audio tracks from your computer. Yes, you can do this. Your Sony system is equipped with an input labelled MD/Video (audio) With a sensitivity of 450 mV, this will (not ideally) the output from your computer headphone jack (if a laptop) or, even better you may have a desktop with an audio output at line level. You will need a simple audio connector with a 3.5 mm stereo plug on each end (very common and readily available for a few dollars. Be careful when setting up that you have your source turned down low and the input on your Sony machine about half way. You will find the sweet settings so that you get good sound without distortion. If you get distortion your source level is too high. Hope this helps. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
I have a Sony receiver/tape deck/cd system, and need a copy of the owners/users manual in order to use the presets and other features to best advantage. The model of the unit is HCD250 or Hcd-G2000. I was...
http://www.givemefile.net/smanuals/hi-fi_hi-end--others/sony/hcd-g2000_26718.html
Above is a service and repair manual for the Hcd-G2000.
Below is your user guide.
www.devicemanuals.com/guide/.../Sony/Sony-Bookshelf-Hi-Fi-System-HCD-F250AV-User-Guide-TXpZek9EST.html
Support links for Sony below.
esupport.sony.com/
HCD250 service repair manual below.
http://www.givemefile.net/smanuals/stereos/sony/file/8297.html
Aug 24, 2010 | Audio Players & Recorders
Do i really need to buy the stk 412-150 ic?
Hi, I got a stereo SONY,model No HCD-GN880 and I need to buy IC STK 412-150. Please let me know if you got any of the stock
Aug 21, 2010 | Sony LBT-ZX8 Shelf System
I need a manual for my SONY stereo. The model no
manual availible at sony website
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HCDHPX9
Oct 03, 2009 | Sony Audio Players & Recorders
 Grubhead
Grubhead
