Question about Frigidaire Microwave Ovens
The micowave does not start. The light works and the time does put does not start to heat
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Kathy, thank you for your inquiry! There are a few reasons why a microwave no longer heats:
Power Supply
Plugged into GFI Outlet
Faulty Control Panel
Faulty Magnetron
Let's try resetting the appliance by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the microwave on. If resetting the power does not correct the issue, then once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your unit is experiencing.
Posted on Aug 02, 2013
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
LG MS-1943ALT Micowave not working, light, fan and turntable all work, no heat
From the decription that you have provided, the magnetron is highly suspect and is the most expensive part to replace, cheaper to replace the microwave oven in the long run.
Sep 06, 2011 | LG Microwave Ovens
Micowave is not heating up, and is making a
It may be a shorted diode in the HV power supply for the magnetron. Open the case to get to the part. Unplug the machine before opening anything. This is normally a high voltage area when running.
Jul 17, 2009 | Microwave Ovens
My oven started arching with micowave popcorn (4 or 5 different times). Now it will not heat. No error messages on the screen and everything else works. Thanks Dennis M.
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jun 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
MR95TW
i need to buy the mr95tw micowave to replace the one i have becouse of the size where can i buy it at?
Jan 08, 2008 | Welbilt MR95TW Microwave Oven
Micrwave starts but then quits
Microwaves should only be worked on by fully qualified repair people and my advice to you would be to bring it to such a person,they can be dangerous to work on due to the presence of such high voltage, other than changing a light bulb any other repairs are out of limit.
Jul 19, 2007 | GE JVM1441 Microwave Oven
Sharp Carousel Micowave
One or more door switches is bad, or the switch mount is loose or broken. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 23, 2007 | Sharp R-320H Microwave Oven
Microwave Ovens Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
