Question about Cell Phones
I have an Ernesto Chip cutter Model Z28519 version 07/2011. The large blade unit has collapsed during use and I want to replace it. Can I get another blade unit, where from, how much ? John Godden - jfgodden@talktalk.net 41,Arden Way Market Harborough LE16 7DB
SOURCE: DeLonghi oil filled heater typ.061563
Hello I have a Delonghi KR031225 found that after turning it on and it heated up it began leaking on the bottom corner on the same panel that holds the controls? What could be wrong? Is it beyond repair?
Thanks
Mel
Posted on Jan 11, 2009
SOURCE: can't find replacement cutter blade for Rival 2275
Go here
http://abtecparts.com/Rival_grinder_2275.htm
Posted on Jan 14, 2010
  • 356 Answers
SOURCE: I need a cutter blade
You can buy it from Waring or Omega, same blade.
Or, just google Acme juicer parts. $20 to $30. Look
out though, found new blade increases vibration. You
can also sharpen old blade by slightly drilling into
each burr on the blade with a small drill bit. Been
using the same blade for several years.
Posted on Feb 03, 2011
  • 157 Answers
SOURCE: stanley retractable utility knife 10-788
Hello. The blade-slide button must be pushed down at full extension, and then pushed forward some more untill the blade can be switched out.
Hope this helps.
Posted on Mar 26, 2011
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Superior tool 37100 blade replacement
From Superior Tool Website, look up the tool, then click on "How to Use".
Blade Replacement:
1. Remove large pivot bolt and nut
2. Slide blade down through handle
3. Remove one (1) end of coil spring
4. Remove "E" clip from 1/4" pivot pin,
remove pin and blade
5. Install in reverse order
6. Torque nut until tool ratchets correctly
Mar 13, 2013 | SUPERIOR TOOL CO superior tool 37100...
What is a paper cutter?
A paper cutter is meant to cut large pieces of paper in a perfectly straight way. The tool is about 30 cm large on each side. It will have a grid drawn on the surface or a ruler along the top. On the right is a blade and it is attached to one corner. The blade lifts up to cut straight edges wherever you wish to cut. There is also a finger guard as a protective feature.
Jan 17, 2013 | Office Equipment & Supplies
Rheem condensing unit fan motor failure?................3rd motor was replaced by contractor on 3 year old unit. Unit starts vibrating very badly and will also start vibrating when blocking airflow. All...
Could be the fan blade is the issue for vibration. Perhaps the blade was bent or somewhat damaged during failures or during the fan motor replacement process.
Might try replacing the blade. Be sure to install the correct blade. Pitch, number of blades as was on the original unit. If blade was replaced previously, the new blade may be pitched or sized incorrectly.
Sep 02, 2010 | Heating & Cooling
Locked in blade
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
May 15, 2010 | Cuisinart DLC-5 Food Processor
Took blades off to clean and oil unit and can't get the unit back together.
First when you remove the clipper blade did you notice a plastic part 1" long color gray, if you have lose this part your clipper blade not work. This is call a blade guide. Clipper blade installation, Place Plastic guide on spring,2 place cutter blade on guide,(this is the smaller blade) now hold cutter blade with two fingers now place comb blade on top of cutter blade (this is the bigger blade) replace screws while holding blades in place.
Mar 21, 2010 | Oster 76974-160 Hair Trimmer
UP-DR100 Error 0008 problem
Problem: The Printer does not detect the Reverse position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or more than likely impact on the lower left side of the printer causing a bend in the metal that holds the Reverse switch.
This switch will trigger a sensor telling the printer that the cutter has reached the Reverse position(left side)
The grinding noise is caused by the cutter carriage rubbing on the inner side of the door panel. The door panel shifted inward and is obstructing the path of the cutter blade.
Solution:Replace the door panel and check for damage on the left side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the left side. Or replace the whole cutter blade assembly.
Any replacement parts can be ordered from imagingspectrum.com.
Jan 30, 2008 | Sony UP DR100 Thermal Photo Printer
Cell Phones Logo
109 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
