Question about California Faucets 1/2" Thermostatic Valve with Rectangular Trim Plate....
I have a Pegasus Luxor kitchen faucet (single handle) that has low flow. I believe it is from a plugged backflow preventer. Where is it located?
2 Suggested Answers
canddplumb
  • 35 Answers
SOURCE: How to repair a pegasus faucet
I was unable to aquire a spec sheeet. I didnt know the model# or name.I did find a web site that had pegasus fausets.Fausets.com I tried to down lode the specs on 1 of there fausets.They wouldnt let me.But i did get you a customer service#1800-444-5783 .I hope this helps
Posted on Dec 02, 2009
How do i remove a single handle kitchen faucet
There is typically a cover plate that needs to be pried off. Under it you will find a screw that needs to be removed. Other types use a set-screw that would be visible at the base of the handle.
Aug 07, 2014 | Pegasus Technologies Pegasus Kitchen Sink...
HOT AND COLD WATER STOPPED COMING OUT OF OUR KITCHEN FAUCET
Do you get water when you disconnect hose from the faucet? If so, perhaps plastic backflow preventor in the faucet is stuck?
May 29, 2012 | Pegasus Technologies Plumbing
My Pegasus kitchen faucet leaks at the top, even when off. I'm not sure which model, it has one handle with a side spray. What do I do.
Turn off water supply to sink. Wrap top of goose neck with rag and use a pipe wrench to remove ( lefty loosey, righty tighty). Inspect interior of faucet for worn o - ring or gasket and take damaged part to local hardware store for replacement parts. The gasket or o - ring may be on the gooseneck ( the part the water comes out of between the handles or below a single handle faucet).
Good luck!!
Nov 29, 2010 | Pegasus Technologies Plumbing
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
No water pressure on Pegasus kitchen single handle faucet
Those new faucets generally have a lower water pressure due to legislation passed in 2007 that reduced that maximum allowable gpm (gallons per minute). I hate to tell anyone this but there is little if anything you can do. First of all, make sure the shut-off valves are open completely. I know that sounds elementary but I've seen it a bunch of times.
Also check to see if the aerator is blocked with a bit of debris.....unlikely if the flow is uniform but still an easy fix.
Hope I didn't break your spirit too much....
Apr 28, 2009 | Pegasus Technologies Pegasus F1225100BN...
Single handle pegasus kitchen faucet. No water pressure when turn
Kitchen faucet? Remove the internal parts and check for blockages.
Apr 05, 2009 | Pegasus Technologies Pegasus F1225100BN...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
California Faucets 1/2" Thermostatic Valve with Rectangular Trim Plate.... Logo
24 people viewed this question
Top California Faucets Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a California Faucets Plumbing Expert? Answer questions, earn points and help others
