Hello, I have a 3 doors Amana refreg that stopped cooling the upper side. I found out that the thermostat is open always. I replaced it and still have a problem. However, now I can run the "force defrost" via the buttons (I coudln't before with the bad thermostat). I am not sure if the JAZZ controller is bad, since all of the diag tests are passing. I do think there is any issue with D-sense - didn't test it yet to see if it switch once per 4 hours. I would like to setup the JAZZ board to a factory reset. Is there any way to do it, or reset at all? What is your opinoin about the root cause of the probelm? Appericate the help! Guy
SOURCE: How do I test the defrost thermostat?
the fan is ctrl by the Jazz board the thermdisc is for defrost post your email and I will send you the manual on test process and test point as well as the defrost
SOURCE: Troubleshooting defrost system failure on Amana Fridge
YES YOU GOT IT,IT'S THE BOARD BECAUSE EVERYTHING ELSE CHECKED OUT GOOD,BOTH FANS,HEATING ELEMENT,DEFROST THERMOSTAT,THE ONLY OTHER THING I WOULD DO IS TURN THE THERMOSTAT OFF IN THE FRIG.TO SEE IF THE COMPRESSOR AND FANS TURN OFF,WAIT 3 MINUTES AND TURN IT BACK ON, IF THAT CHECKS OUT THEN IT HAS TO BE THE DEFROST TIMER,LET ME KNOW-MIKE
