Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
I have a old Whirlpool Dishwasher model du920PFGQ4
I have a old Whirlpool Dishwasher model du920PFGQ4 I think it is a Q )serial fk5220288. For awhile I was having trouble getting the dw to turn on. I would have to push the buttons several times but I would always be able to get it to turn on but not anymore . Only the cancel and drain will work. Please advise. I dont have alot of money for repairs so I was hoping this would be something I could repair.
  • 65 Answers
SOURCE: Won't start!
toggle between 'heated dry' and " normal ' until all light illuminate Then press cancel. now ensure door closes properly without striking cabinets slightly. The neutral for most components run through the door switch and jarring actiong causes a fault to be stored in computer. the toggle dance clears the fault code otherwise it will "fault code "again in three operations. hope this helps.
Posted on Feb 16, 2008
  • 188 Answers
SOURCE: We have a kitchenaid dishwasher model#kud102irbl
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
  • 530 Answers
SOURCE: whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Posted on Apr 14, 2009
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
SOURCE: Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Posted on Aug 24, 2009
New Whirlpool DW, has run once, now won't start. When I push the start button the 'normal cycle' and 'heat dry' lights up briefly. Power supply is intact, door latched and 'delayed start' not on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Dishwasher.
Jan 21, 2017 | Whirlpool Dishwashers
Why am I getting an error code iCO on my frigidaire gallery dishwasher?
I just addressed a iCO error code on my 2 week old Frigidaire Gallery DW. I reset the circuit breaker as recommended online and it worked fine for another few days and then came back. Customer service cannot tell me what the error code means. They WILL NOT replace the DW, rather want to schedule a service appointment. I have no desire to repair a new DW so I am receiving a refund from the retailer I purchased from. On to the next brand!
Aug 18, 2014 | Frigidaire Gallery FGHD2465NF Fully...
Dishwasher whirlpool model number du1030xtkq2 will not finish cycle
Check the float to be sure it is unstuck. Sometimes this item [on the basin of the DW, looks like a mushroom. Measures the water level in the bottom of DW] is tricked in thinking it has water, or the water is not turned on, or the basin is full. Gently pull up on it and push down on it. Does it move freely?
Try to cycle again.
Nov 24, 2013 | Whirlpool Dishwashers
My dishes are not getting clean anymore! It's extremely frustrating. Also, sometimes my soap doesn't even dissolve! This dishwasher isn't very old, but I am tired of it!
hi, This is a water temp. problem. The first fill s/b about 125-140 degrees. You can try running your hot water tap for several minutes. Run a load, see if there is some improvement. Next, go to your water heater, see where the setting is. On a gas move dial up a notch. On electric remove top and bottom covers and do the same thing. You also need to clean the dw off and on. Take a gallon of white distilled vinegar and pour the whole gallon into the dw after it has started and run for awhile. Then open the door and let sit overnite, starting the next morning. Hope this helps.
Jan 17, 2011 | Whirlpool Dishwashers
Dishwasher clean light is blinking
indicates a problem with dw not heating the water. various causes. dw should be thoroughly checked, if nothing found wrong, reset computer
Jan 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
My Whirlpool Gold Quiet Partner III dishwasher will not start. I have installed a replacement control board that worked for awhile. When it quit I put the old control board back and it worked for awhile...
Hi Cathy, we are sorry for the concerns. We would advise service with an authorized servicer. If you would like to schedule service please email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and model/serial number.
Apr 11, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool dishwasher model DU920PFGB4 will not start.
my dishwasher is only 2years old and will not start. the lights on the panel come on but wont start.
Sep 26, 2009 | Dishwashers
Bosch Model SHU4006UC problem
OK.. I'm a little confused.. I looked up the model # you have posted and found that there is no dial to turn on your dw... unless its the wrong model #.. it only have push buttons.. Anyway.. I think its your control.. yes, you can ohm out your elemnt if you can get to it..there is also a switch that is in series w/the heating elemnt.. make sure that is working.. from my trainning, most of the time its the control.. look for burnt mark by the 110-120v where its plugged in on the control.. let me know..
Jan 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Oct 09, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
44 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
