SOURCE: Need For Speed Prostreet... error when I start the game on my PC
on the disc or where you got it from there are important files missing that reqires to run the game. Hoem it helped
SOURCE: PLAY PS2 GAMES ON PC
Ok, you want a full procedure here it is. First of all if your computer does not meet the following specs stop reading cuz you'll be wasting your time trying to get it to work and will be very disappointed by the quality of game play:
Minimal Specs:
AMD 64 or Intel Pentium 4 (VM Build will not work with non SSE2 CPU's)
512MB of RAM
Pixel Shader 2.0 supporting card
Recommended Specs: (For reasonable performance in many games, but not all)
AMD64 X2 or Intel Conroe E6600+ (Multi Threading is supported in PCSX2)
512-1024MB of RAM (more RAM allows for VM mode to be stable)
Pixel Shader 2.0 supporting card (recommended GeForce 6600-8800 or equivalent ATi card)
Possible Ideal Specs:
64bit OS such as Vista or winXP64, to allow for future support of 64bit recompilers.
Future AMD or Intel Quad Coremaybe needed, but currently the support of 4 threads is not handled byPCSX2, and the effect of threading out EE / VU is not yet known.
We don't forsee you requiring a GPU more powerful than the current generation of cards, up to and including the nVidia GeForce 8800.
Also note, if if have just a standard AMD Athlon (non64) don't even bother trying to run this emulator. It does work but is very very slow.
If you meet at the very least the minimum specs go here and download PCSX2 Binary. .::CLICK HERE::.
This is the BEST PS2 emulator currently on the net. There is NONE better.
Next: as with any emulator you need a BIOS in order to use it. There are several methods to getting a PS2 BIOS. You can google "PS2 BIOS download" or check torrent sites like this one .::HERE::.and do a search for "PS2 BIOS". At any rate, get 1 or many BIOS(one for each different area ex. Japan, US, Europe)
Next: Un-7zip the PCSX2 7zip. Take the BIOS.bin files you downloaded and place them all in the folder, "bios" in the PCSX2 folders you unzipped.
Next: You'll notice two icons that look the same one is called pcsx2.exe and one is called pcsx2t.exe. I have had no luck getting anything to play worth a **** on pcsx2.exe. I use pcsx2t.exe. According to the person who made this program, pcsx2.exe is a faster emulator version, but he says that AMD people have had better luck using pcsx2t.exe. So, if your computer has an AMD processor try the pcsx2t.exe first. But keep what I said in mind cuz you may have to use the other one instead. In either case, choose one and run it.
Next: When the program opens, it will have to be configured. Look at the top of the program and click the, "config" menu option. Next click the, "configure" menu option. You are now faced with several configuration options. I'm not even going to bother explaining what each option does, go .::HERE::. it explains what everything does. 9 times out of 10 when pcsx2 won't work, it's cuz of a bad configuration. SO MAKE SURE YOU READ THAT WHOLE PAGE.
As you can see there two ways you can load a game. Either by turning the game itself into an ISO or from using your DVD-ROM drive.
As far as controlers go, you can purchase USB PS2 look alikes from most computer stores. You can also get PS2 to USB converters that you can plug directly into your computer. And there is even a SIAXIS driver floating around on the internet that will run a PS3 controler as if it was a standard computer game controler. If you don't have money for a controler or what not just use the ZeroPAD option under, "First Controler" and start binding keyboard keys to assigned slots.
As with any emulator nothing is perfect and this will not play every single PS2 game out on the market. However, this is the most current emulator in production atm and is the furthest along. When you get everything up and running you'll want to look ..::HERE::. at the compatibility list to make sure your game is registered to even work with this emulator.
Hope that helps,
L8er
SOURCE: I have a new ds game stuck in the slot - please help
the pin is stuck down try powering the unit down and pulling it out by hand, dont use any tools.
then see if another game will click into place.
SOURCE: Wii Won't read disk
easy fix
call nintendo. If its only one particular disc thats having the error, its the game. If it is more than one game, its the system. Call them and talk about troubleshooting and see if there is anything you have not tried.
SOURCE: playstation3 is not loading games at all
I had a similar problem. My PS3 did not load the disk based games.
Those disk based games were not visible in the game menu. I did not
have problems with the normal movie DVDs or Movie Blu Rays. Those were
working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After
PS3 has executed the DB rebuilding operation, the disc games will be
visible again in the menu and are starting automatically when inserted
to PS3.
