Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn-Air JCD2389DES side by side refrigerator not working I hear a clicking no cooling in either side compressor does not work
  • 27 Answers
SOURCE: jenn air JCD2290HES Refrigerator not cooling
Try defrosting ther could be an ice buildup in the channel between the fridge and freezer.
Posted on Feb 23, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
  • 72 Answers
SOURCE: Jenn Air Freezer Works, Refrigerator Does Not Cool
check the damper which provides air flow to the fresh food side
Posted on Jun 07, 2009
omaharox
  • 166 Answers
SOURCE: Jenn-air JCD2389DES stopped cooling in both the
2 things may cause this condition.
1. The relay and overload which starts the compressor has failed.
This is an easy fix.
2. The compressor has failed.
The compressor can be replaced and is worth doing if the unit is in good shape.
Posted on Jan 15, 2010
woodchuck789
  • 4070 Answers
SOURCE: Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Posted on Jul 13, 2010
Jenn-Air side by side Model #JCD2389DES. We noticed freezer was only doing a soft freeze..we removed several items which we thought were blocking vents in freezer...next we noticed refrigerator side was...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Jenn-Air JCD2389G Side by Side...
I have a Jenn Air side by side refrigerator that started making a humming and clicking sound last night and this morning it stopped cooling on both sides. What could it be?
heatman101
Nov 24, 2010 | Jenn-Air JCD2389G Side by Side...
Hello, My Jenn Air refrigerator will make a humming sound and click and continue this for about an hour and then the compressor will start.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 07, 2010 | Jenn-Air JSD2789GES Side by Side...
JENN-AIR WONT COOL THE LIGHTS ARE ON BUT IT WONT GO COLD
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 23, 2010 | Jenn-Air JCB2282H Side by Side...
I have a Jenn air side by side refrig/freezer
Hi rdiorio.
you could have one of many faults, either thermostat, compressor or if electronic maybe that have failed. If the Thermostat starts to fail it can produce eratic readings which freezer the chiller part of cabinet, then it can fail completly. What ever you do remember 240 Volts kills. Use a qualified person when dealing with electrics... Cheers
Mar 29, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn-air JCD2389DES stopped cooling in both the refrigerator and freezer. I hear a click sound every now and then. It sounds like it is clicking on but then nothing happens. The clicking sound is coming...
Jan 15, 2010 | Jenn-Air Refrigerators
I have a Jenn-Air JCD2389GT and it is not cooling correctly. It is on with settings in the middle. Why is it not cooling?
heatman101
yt785
Jan 07, 2010 | Jenn-Air JCD2389G Side by Side...
My Jenn Air JCB2285HES not cool on both sides not frozen line
heatman101
jljhfjg
Oct 21, 2009 | Jenn-Air JCB2285HES Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
