Question about Parrot Radio Communications
I purchased two of these one is fine but the other worked for about a week now it wont turn on It was on but would not pick up calls when I touched the buttonso I shut off the bluetooth on my phone which in turn forces the headset to shut down after a couple of minutes and now wont turn back on below is the order date and info. I have owned several of these this is the first time I ever had one stop working I usually break the headbands on them before then but they usually last about a year before I do that order Number110-4446937-8944223Order Placed Jun 7, 2013
  • 40 Answers
SOURCE: Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Posted on Jul 03, 2007
  • 586 Answers
SOURCE: T V Shuts off by itself, after a couple of minutes.
here is some tips for ur TV which blinks 4 time.
1 Probable
Solution • +13V is not supplied.
(A Board)
• IC503 voltage list is faulty.
(A Board)
• Has entered standby state
Solution after horizontal raster.
•Vertical deflection pulse is
•Power line is shorted or power
supply is stopped.
this info must remady ur problem.
Posted on Dec 25, 2007
  • 3 Answers
SOURCE: Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off.  Try holding both volume buttons at the same time for a second or two.  If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up.  On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume.  My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
Posted on Dec 31, 2008
SOURCE: garmin bluetooth won't disconnect call
Solution below works for NUVI660 as well; ignore everything after step 6 but DO reboot and delete previously existing connections.
good luck
I was having the same problem with my Curve and Nuvi 680. What has fixed this for me is downgrading the Bluetooth firmware version on the Nuvi itself. I was running version 3.0 (you can check your version by going to Settings -> System -> About on the Nuvi) -- I had success after downgrading to version 2.4.
It's a bit of a convoluted process, but here is the procedure I followed:
1. Download the old Nuvi BT firmware from the Garmin Italy website:
2. Connect your Nuvi to your PC.
3. Go into the X:GarminRemoteSW and look for a file called 006B055301.GCD (where X: is your Nuvi drive)
4. Back up that file to your
computer, and delete it from the Nuvi.
5. Extract the file in the zip downloaded in step 1 to the X:GarminRemoteSW directory
6. Disconnect your Nuvi from your computer, and let it
7. Click on "View Map," then touch the "Speed" in the lower left corner.
8. You should have the "Dashboard" view up. Touch and hold the "Moving Average" box for ~15 seconds until the diagnostic screen appears.
9. Press the "next" button until you arrive at the "Bluetooth Status" screen (5-6 screens in)
10. Click "Updt PR" and then click "Yes"
11. Reboot the Nuvi, delete the existing bluetooth pairing, and attempt to re-pair with your BlackBerry.
Seems to work perfectly now -- please let me know if you have any questions. Good luck!
Posted on Feb 21, 2009
  • 126 Answers
SOURCE: TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Posted on May 01, 2009
I just got my kurio 7s last week and now the wifi wont work. the wifi turns on and its picking up my router even says it has perfect signal i hit connect then it keeps going through this 10 min ****...
If you can click on your wifi and pick "forget" do that and then restart the tablet and try again. If that doesn't work try going to settings and resetting it to factory then it will be like a new one, if you can do it without wifi some tablets wont let you past the wifi screen until you sign on.
Apr 03, 2017 | Techno Source Kurio Kids Tablet With...
Vehicle was purchased used in January 2010 and is in excellent condition and all electrical system was working. Approximately a week after purchased we had an alarm installed. when vehicle was picked up...
you need to take it back and see what they can do for you something is wire wrong i maybe wrong but i believe the pt cruiser comes with a alarm call your local Chrysler dealership and talk with the manger or a service writer about your car wish you the best of luck Michigan Man.
Oct 17, 2010 | 2003 Chrysler PT Cruiser
The touch feature is not working. When I touch the screen nothing is happening. I cannot make any calls or text. What do I need to replace to fix it? I can receive calls.
my phone feel in beer.... i dried it by the fan over night and was working fine for about four days. On the fourth day the touch screen didn't work, but all my buttons work. I can pick up phone calls, call the last person I talked to, and it also charges. Is there any way to fix my touch screen???
Mar 22, 2010 | LG Dare VX9700 Cell Phone
Won't turn on
Remove battery for at least one minute, then reinstall battery and try again, if mp3 player still won't play replace battery. If the unit still doesn't work then it must be sent to manufacture for repair if still under warranty. If out of warranty it may be cheaper to purchase a new unit.
Jun 10, 2009 | Creative Labs Zen Touch MP3 Player
My 1992 toyota standard pick up wont start
Check the connections at the starter and battery agian before you start looking to replace the starter.
Nov 05, 2008 | 1987 Jeep Wrangler
Hp pavilion dv5 dual core pentium duo
u have to install driver then it will works
Oct 25, 2008 | HP Pavilion dv6000z Notebook
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
If you have purchased the cartridges directly from dell , it will be covered under warranty for 2 years for hardware errors and you can call dell on 1800 624 9896 and get the cartridge replaced , even after the replacement of the cartridges if you have the similar issue then its an issue with the printer and needs to be replaced.
Jun 24, 2008 | Dell 922 All-In-One InkJet Printer
Arcing Picture tube
get a different tech from a different store to come out, needs to replace convergence ic's good luck
please mark the post with a fixya
Feb 16, 2008 | Toshiba 65HDX82 65" Rear Projection...
Radio Communications Logo
29 people viewed this question
Top Parrot Radio Communications Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
