Question about Samsung Gt S3650 Corby - Cellular Phone - Gsm - Touch -
Touch slot problem
I want a way to fix the touch
  • 4 Answers
Try to reinstall kernel.
Posted on Aug 01, 2013
I put a sim card in the TF slot it burn my sim card out how do i fix it
buy a new sim card and don't put it in the slot
find out the purpose of the TF slot first and it may be faulty
Jan 18, 2016 | Tagital Tm 9" Android 4.0 Tablet PC...
All of a sudden my dragon touch has lost all of the apps were on my sd card what can i do
Go to Settings>Storage>External SD and look for the *unmount* option. Touch *unmount*. This will electroncally close the SD Card connection so it can be safely removed from the slot. Then remove it from the slot. Then clean the brass contacts with a little piece of toilet paper. Then slide the SD card back into the slot.
The device should automatically *mount* the card. If it doesn't and there is a mount option shown then touch *mount*. If it still doesn't work then chances are your SD card went bad. They do that sometimes.
Jun 23, 2015 | Dragon Touch Tablets & eReaders
How do I fix the charger slot on my tablet? the charger wont stay in the slot
I had this problem too. You can either use an android phone charger (easiest) or you can wrap the charger around it from top to bottom, still having it plugged in.
May 15, 2015 | Kurio Touch 4S Handheld
My daughters ds lite has a few problems. The calibration is out and wont fix when i calibrate it. It wont play ds games but will play gameboy games. Please could you tell me if these problems cn be fixed?
The touch screen may be faulty but can be replaced. The SLOT 1 game slot may have bent pins or broken pins. Bent pins can be easily fixed (with care and patience) but replacing the SLOT 1 or the touch screen is quite difficult. It is probably repairable but only by someone who knows what they are doing.
Feb 15, 2011 | Nintendo DS Lite Console
My oven is saying F7 d6. The d6 is flashing. The oven is beeping. It is a GE model number jsp42s0k4ss
Sorry to read about your problem, I hope this helps you out.
Do you have the dreaded F7 message pulsating from your oven? The original purpose of the F7 message is to signal a stuck START key, which is a rare occurrence.
The more common cause is a type of short circuit that occurs in the touch panel near the cable slot. The fix that I will describe addresses this type of fault. It will not fix a stuck START key. It will not fix a faulty Electronic Range Control (ERC). If you are getting other errors, such as F1, the fix may still do the job. F0 is usually a shorted off key.
Cleaning the ribbon cable connector is a myth. What you accomplish is to temporarily disrupt the short circuit occurring near the slot in the touch panel. With time the short circuit grows back. It happens more often when the humidity is high. So here is my solution to the F7 problem.
The most important step is first turn off the power to the oven at your circuit breaker panel.
You will need to open the touch panel. There are typically three small screws on the bottom edge of the touch panel. It is advisable to have an assistant to hold up the panel while you work on it. Pull the panel outward at the bottom to gain access. There are many wires attached to the panel. Do not allow the panel to dangle by the wires.
When the panel is open, you will see a flat ribbon cable connecting the ERC to the touch panel. See photo # 1. The principle of the fix is to apply additional insulation in and around the ribbon cable at the slot where it exits the touch panel.
There are three basic styles of touch panels. Here is how the fix is applied for each style.
1. Plastic touch panel with a two-segment ribbon cable.
Apply a slip of paper or file card material between the two segments of ribbon cable in the area of the slot. Work the paper down as far as it will penetrate. Typically it will only go in about 1/8". See photo # 2.
2. Metal touch panel with a two-segment ribbon cable.
Apply the extra insulation as per style 1. In addition, apply extra insulation on both sides of the ribbon cable and the edges of the slot.
3. Metal touch panel with a one-segment ribbon cable. Apply the extra insulation on both sides of the ribbon cable and the edges of the slot.
If your style is different from the above three styles, the fix will not work for your situation.
Don't be concerned about using paper for the insulation. It will not get hot enough to burn. You will probably find a set of instructions printed on paper in the top of the oven when you open the touch panel.
If the fix doesn't work for your situation, you will need to replace either the touch panel or the ERC. Here is how to determine which one is faulty.
1. Turn the power off.
2. Remove the ribbon cable connector from the ERC.
3. Turn the power back on.
If the F7 does not appear after a few minutes, the problem is in the touch panel and it must be replaced.
If the F7 returns after a few minutes, the problem is with the ERC and it must be replaced or repaired.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Microwave Ovens
My dell will not turn on I have played with the
You might not have the memory snugly placed into the slots. Also, you may have ruined the memory by touching it with your fingers if you didn't discharge your static electricity first. Try both memory sticks individually and only in slot A. If they work seperately and both work, either slot B is damaged or you have different types of RAM. possibly ecc
Mar 04, 2010 | Dell Inspiron™ E1505 PC Notebook
Voda-Phone V2 - Touchscreen doesn't recognize touch
Try to put only one SIM card in slot #2.
Now maybe the touch screen is working-
If not, try to put only one SIM card in slot #1.
The problem could be the 2 SIM card at the same time (also if it should be recognize 2 in the same time).
I have seen a V2 with this problem. Regards, davide
Dec 24, 2008 | Vodafone Mobile Connect (055270) Wireless...
F7 error
I am assuming you have two sections to the ribbon cable and a plastic touch panel. Try cleaning the area between ribbons in the area of the slot in the touch panel. Use alcohol and a Q tip. Let it dry. Try forcing the business card further down into between the ribbon cables. If you have a metal touch panel, you need to apply insulation between the ribbon cable and the edge of the slot. Refer to my instructions at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
If this doesn't help, you have a short in the touchpanel at some other location and my fix can't reach it. You will need a need touchpanel.
Jul 05, 2008 | GE Profile JTP18 Electric Single Oven
A freezing nintendo lite!
The DS Card Slot may be loose. If so, try not to touch the game card while playing.
Or, there may be a piece of dust or lint in the card slot. If you can see the lint, pick it out with clean tweezers. If you cannot see it, ask a mechanic to open the Ds and pick the dust out.
Jun 10, 2008 | Nintendo DS Lite Console
Gameboy advance sp not working
Try taking the game out, blowing air through the slot and through the GBA's game slot, reinsert the game and try again.
If it doesn't work with any games make sure the slots are dust free.
If it doesn't work with any game it might be an internal problem and you'd be forced to get a new one or get it fixed or even fix it yourself.
Good luck.
Feb 26, 2008 | Nintendo Game Boy Advance SP Console
Samsung Gt S3650 Corby - Cellular Phone - Gsm - Touch - Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
