Question about Ford Vehicle Parts & Accessories
My alarm goes off when the doors are locked and the door ajar light comes on when I am driving and it dings but the doors are all shut, what could be wrong? I have a 2007 Ford Escape
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
Sensor that tells the door is closed is eather bad or out of adjustment
Posted on Aug 02, 2013
4 Suggested Answers
  • 740 Answers
SOURCE: alarm wont shut off and lights keep flashing
This can be very simple look for alarm brain and unplug the brain, this vehicle should start. if it doesn't the look for valet switch it usually mounted under dash or on kick panel next to hood lever or close to where clutch pedal will be, Turn Ignition ON and in ON position flip switch the led light should stay on steady then the vehicle will start. If None of this works then you will have to take panel under steering column down and disconnect complete alarm system. Disconnect wires one ar a time and re-join them with the correct ones. It's NOT hard to do, there will be spliced into ignition wires.To do this you should disconnect positive lead on battery pole to stop the annoying noise until you are done. Good luck and contact if you need more help. Thanks for using FIX YA
Posted on Mar 24, 2009
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
SOURCE: How can I disarm the anti-theft alarm on my 2004 Ford Escape?
How can I disarm the anti-theft alarm on my 2004 Ford Fiesta
Posted on Nov 25, 2009
Door ajar light comes on and doom light showing drivers side door open.When doors are locked the alarm goes off
Check rubber bung in door makes contact with door shut sensor on car body. May need to replace the rubber bung in door.
Mar 21, 2015 | 2006 Chrysler 300
How to turn off door ajar chime on a 1998 Ford Windstar
your door switches are probably dirty spray them with wd40 then scrub them with a tooth brush
May 30, 2014 | 1998 Ford Windstar
Door ajar lite comes on and the alarm keeps dinging all doors are in line and closed how to make the ding stop?
first of all, you may have one or more door buttons that are bad. spray all door switches with a good spray lubricant and see if this helps. if not, find bad one and replace it. if door switches are bad door ajar light will think door is still open.
Aug 14, 2010 | 1994 Dodge Caravan
Door ajar light & washer fluid light & bell dings,
sound like your fluid sensor may be stuck or bad if light stays on try tapping the washer motor on the resevoir if it goes out faulty sensor as for the door ajar light it might have bad connection with sensor saying the door is closed local dealer should be able to troubleshoot sensor
Aug 23, 2009 | 2003 Ford Expedition
Door ajar light - power windows and alarm
you may have a broke wire in the door harness
Jul 16, 2009 | 2002 Ford Explorer
Doors lock and unlocking in gear
Sounds like a short in the lock switch or in one of the doors. Eliminate each one step by step by unplugging each unit one at a time and see if the problem goes away. Start with the lock button that you push to lock and unlock the doors from the inside. This switch tends to get a lot of soda and coffee spilled on it and it shorts out.
Jun 02, 2009 | 1995 Dodge Caravan
Alarm goes off by its self, dome light comes on by its self
I read a service bulletin about door ajar light and power locks cycling while driving which i assume might actuate dome light as well.... rec. fix per service bulletin adjust "swing gate " striker
Good Luck
Apr 08, 2009 | 2006 Hummer H3
Door ajar alarm comes on while driving.
there is a switch in each door that senses the door is open, it is called the door ajar/courtesy light switch (imagine that), they stick and have this problem, replace it.
Mar 25, 2009 | 2001 Volkswagen Jetta TDI
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
