Question about Ford Vehicle Parts & Accessories
Car alarm keeps going off
Alarm goes off when the doors are locked and the door ajar light comes on when I am driving and the doors are shut, what can I do to fix it?
  • Henderson Aug 02, 2013
    if newer could have a valet mode messing u up, look in you manual to turn it off.
    Problem Solver:
  • 19 Answers
Make model and year?
Posted on Aug 02, 2013
  • 740 Answers
SOURCE: alarm wont shut off and lights keep flashing
This can be very simple look for alarm brain and unplug the brain, this vehicle should start. if it doesn't the look for valet switch it usually mounted under dash or on kick panel next to hood lever or close to where clutch pedal will be, Turn Ignition ON and in ON position flip switch the led light should stay on steady then the vehicle will start. If None of this works then you will have to take panel under steering column down and disconnect complete alarm system. Disconnect wires one ar a time and re-join them with the correct ones. It's NOT hard to do, there will be spliced into ignition wires.To do this you should disconnect positive lead on battery pole to stop the annoying noise until you are done. Good luck and contact if you need more help. Thanks for using FIX YA
Posted on Mar 24, 2009
SOURCE: Have 56 plate seat leon 1.6 .the alarm keeps going
I have Seat Leon 07 and my alarm has gone off loads of times in the last 18 months. The first time it was the window motor that went - went in under warranty and part replaced - it's now back in the garage getting the same problem fixed again. the neighbours are fed up with the alram going all times of the day and night. Hope this helps
Linda
Posted on Sep 18, 2009
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
SOURCE: Keyless Entry doesn't unlock my doors anymore
Did you get help? My problem is similar but not as bad. My viper550ESP no longer remotely unlocks the doors (well very, very occasionally it does). That is the only problem.
Posted on Nov 25, 2009
  • 7 Answers
SOURCE: How can I disarm a prestige car alarm system
find the program button and turn on ignition without starting the engine and press and hold the button till it goes steady
if it has a swith turn on and flip the switch till it goes on solid 1 or 2 x
Posted on Dec 15, 2009
Door ajar light comes on and doom light showing drivers side door open.When doors are locked the alarm goes off
Check rubber bung in door makes contact with door shut sensor on car body. May need to replace the rubber bung in door.
Mar 21, 2015 | 2006 Chrysler 300
97 lincoln continental door ajar light and alarm keeps going off
The latch striker post needs to be adjusted. check for broken plastic roller on the post.
May 23, 2017 | 1997 Lincoln Continental
Car alarm went off reset went off again within 3 min had tomanual lock , dome light on while driving
it sounds like you have a door open that is why the light is on. it may not be a actual open door but a faulty door ajar switch. that would explain why the alarm keeps going off. i would start by opening and shutting all doors includingthe hood and hatch.
if that does not fix it-a gm dealer with a tech 2 scanner should be able to located which door ajar switch is bad.
Aug 11, 2010 | 2003 Saturn VUE
2003 Jetta Door ajar light keeps coming on and
You need to replace the door jamb switch. Little button on the door jamb that is pressed in when doors are shut.
May 03, 2010 | 2003 Volkswagen Jetta TDI
Alarm goes off by its self, dome light comes on by its self
I read a service bulletin about door ajar light and power locks cycling while driving which i assume might actuate dome light as well.... rec. fix per service bulletin adjust "swing gate " striker
Good Luck
Apr 08, 2009 | 2006 Hummer H3
Door ajar alarm comes on while driving.
there is a switch in each door that senses the door is open, it is called the door ajar/courtesy light switch (imagine that), they stick and have this problem, replace it.
Mar 25, 2009 | 2001 Volkswagen Jetta TDI
"Door Ajar" signal on dash panel stays on even when doors are clo
there should be a switch mounted( or more than one) in the door jamb that tells the car when the car door is open...i will probably look like a little plastic plunger...might be broken off or bad internally
Feb 22, 2009 | 2008 Pontiac G6 Sedan
Vehicle Parts & Accessories Logo
48 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
