Question about Mitsubishi WD-52525 52" Rear Projection HDTV
MITSUBISHI WD82737 ERROR CODE 37 - Mitsubishi WD-52525 52" Rear Projection HDTV
    Champion:
  • 213 Answers
37 code fan engine BAD FAN OR FAN NOT GITING POWER LOOK TO SEE IF IT RUNING
Posted on Nov 25, 2013
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
Mitsubishi wd60735 code 37
A 37 error code means one of your fans is bad. It would either be the DMD fan, or the lamp fan. Take the back cover off of the set and tape down your lamp safty switch. Turn the TV on and see which fan is not working, and replace.
May 17, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Same as jasonvonk mar 15 2010 I get error code 37 after device and menu buttons pushed. red lite blinks 4 short pause and 4 short again Jim
37 is lamp or dmd failure. i don't find anything on 4 red blinks.44 error code which is 4 blinks, and then 4 blinks in disconnected DVI cable from light engine.
Mar 25, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62327
The error codes are all different for the various models. But your WD62327 is the VK26 chassis DLP heres the error codes and the meaning for your model. Let me know if you need more help.
12 No Error detected, check Power Supply
32 Lamp Cover is open
33 Air Filter Cover is open
34 Lamp abnormality
36 Light Engine (DMD or LAMP Fan stopped)
37 Exhaust or Lamp Ballast Fan stopped
38 Lamp temperature high
39 DMD temperature high
41 Short is detected
44 DVI cable between FMT & Engine disconnected.
May 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
