Question about Garden
Changes shift cables on DRM500, mower shuts off when blade engaged in forward direction. Suspect the shift lever safety switch needs adjusting. How do I adjust this switch?
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman riding mower Model 917.270824
I do not believe there is a manual available to the public for troubleshooting, however, you have at least 3 switches to tell the mower to stop when blades are engaged or clutch pedal released.
Seat switch
pedal switch
mower engage switch
The pedal and mower lever switches are identical, and have two sides, one for starting, one for blades turning. One side can fail. The pedal switch is on the frame very close to the pivot point of the pedal/shaft. The mower switch will be under the dash close to the bottom of the lever.
1) Locate and inspect the switches for broken or pinch wires, switch housing, or loose mounting, and how each lever or pedal engages the swtich.
2) This is a picture of the wiring so that you can get a better idea of location.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00011&componentDescription=SCHEMATIC%20DIAGRAM-TRACTOR&documentId=P0811014&blt=06
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00001&componentDescription=ELECTRICAL&documentId=P0811014&blt=06
Posted on Nov 11, 2009
  • 54 Answers
SOURCE: Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Posted on Apr 28, 2010
  • 640 Answers
SOURCE: The mower blades don't properly
This can happen when the engaging mechanism on the mower deck can not move properly. This could be because there is debris on the deck that is causing interference. It can also happen if you have some corrosion on the deck that is resisting proper operation. So, clean the deck, this is best done by removing the deck. It usually is not very hard to remove, just remember what you pulled off and how it goes to put it back together. There may be half a dozen pins to pull and then move the cable or linkage, raise the mechanism and the deck should slide out pretty easy. Inspect and clean the deck. Then manually manipulate the tensioning pulley, this may take some force to do, depends on the one you have but you should be able to do it by hand. Lubricate if necessary. While the deck is out inspect the belt for wear and replace if necessary. Reassemble and test.
Please rate if this was helpful.
Posted on Jul 11, 2011
  • 5370 Answers
SOURCE: I have a John Deere 102 riding mower with a manual
Check the belt its not tight, its loose or not fitted right.------ May be you put the belt loose or not properly.------ I agree belt is new, the belt is not the problem but its placement is problem.its coming out of its pulleys.Recheck that belt is intact and in-place and not getting loose.-------- Also recheck the connection of pto switch and seat switch.Remove the switch one by one and by pass it with a jumper wire and see if the blades getting engaged.------- ----------
Also check the bolt that holds the idler arm to the deck ,that bolt gets worn out causing the the arm to move up and down. ---------- This will help.Thanks.Helpmech.
Posted on Jul 14, 2011
After the mower is used for awhile and the direction controls are pulled back to go backwards the blades stop and when the controls are pushed forward the blades do not reengage.
George, this is a safety feature built into the mower, the switches can be unplugged, but remember they were in place for your and others safety.
Mar 22, 2016 | Garden
My lawn mower model 425613x8a only drives in reverse what is my problem and how do I fix it?
I'am not to familiar,with this model number,of this tractor. But i do know that there is a safety switch,installed below the shift lever. Usually this switch,controls the neural,forward and reverse for your tractor. I suspect the forward motion contact is bad in the switch itself. You will have to remove the motion drive assembly and purchase a new switch,sometimes the safety switch is part of the whole assembly. You can find this assembly,under the shifting lever under the tractor,s floor. It could be on the right side or the left side depending on the location of the shifting lever.Sincerely,Brad Locke DTD 12/03/15
Sep 07, 2013 | Sears Garden
Mower runs fine but shuts off when the blades are engaged.
This sis a micro switch issue, start by checking/replacing the seat switch, make sure the block connecter is fully pushed home onto the micro switch.
Jul 21, 2012 | Garden
Craftsman riding mower wont start without having to pull up and down on the blade engage lever
Hi, there is a safety switch on the deck engagement that is faulty or needing adjustment, regards Phil.
Jul 10, 2012 | Craftsman Garden
Mower dies when directional pedal ( F/R) or engageing blades
check the safety switches start with the one on the pedal
May 16, 2012 | Garden
Seat switch
pedal switch
mower engage switch
Nov 11, 2009 | Craftsman Garden
When I engage the mower blades, the tractor tries to stall
Hi..my name is Keith..and the newer mowers have all kinds of safety switches..and the mowers will shut off..if you put the mower in reverse with the blades on..so i would suspect you have a bad reverse safety switch..i hope this will help..if not please write me back
Jul 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
May 14, 2009 | Mtd Garden
Mower starts but when the blade is engaged it stalls. Mower starts fine but when I press the lever to engage the blade the mower stalls immediately?
Check the pulleys on the deck...one of them is jammed or rusted to the point that will not turn.
Apr 04, 2009 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
