Question about E-Machines eMachines Desktop PC
"popped" when power button was pushed to start up. No Power
  • 813 Answers
Sounds like your power supply went out you can buy one for about 30 dollars and are very easy to install. Just plug and play
Posted on Aug 04, 2013
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Model MID1042 coby tablet want start up
Replace device under warranty if applicable.
Apr 02, 2014 | Sony Tablets & eReaders
No Power. Popped when power button was pushed
1.plz check SMPS power supply.
2. may be damaged power button.
3. may be problem main board or CPU fan
4. may be problem power button cable
Aug 01, 2013 | eMachines EL1852G-52W
I have a sharp aquos lc-c5277un. Both the power and OPC lights together blink twice. I tried unplugging it, holding down the volume up and channel down buttons while plugging it in. That left me with a...
Could be either or both. The power supply board probably gas an electrolytic capacitor that has failed. Same goes for the main board. When you can hear a pop, you'll be able to visually locate the failed part. Capacitors must have a flat top on them. Any bulging or domed capacitors need to be replaced.
May 10, 2017 | Televison & Video
Power button lock icon keeps popping up on screen. tried to push reuird buttons to fix. buttons on monitor are not working properly.
Push and hold your monitor's POWER button until the monitor shuts off completely.
After it is shut off, press the POWER button again to turn it back on and the lock should be disabled.
Sep 04, 2011 | ViewSonic Va2431wm LCD Monitor
When you push the power button, the button turns green but the computer doesnt start up. The lights are on but there is nobody home, there is no sound indicating that the computer is starting up.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 18, 2011 | Acer Aspire 9300 Notebook
DEWALT DG6300B NO POWER OUTPUT
Hello avid.....
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Nov 27, 2010 | Garden
Pininfarina has no power to anything when key is turned on.
you do have some power or it wouldn't start on a push. Ckhk your connections to battery. Remove, clean and reinstall.
May 22, 2009 | 2005 Fiat Pininfarina
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on).
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Oct 11, 2008 | Dell XPS 200 PC Desktop
Power on/off button not working on a garmin streetpilot III
at the top of the GPS thers a power button
take an eye glass flat head screw driver and pop the power button out there should be a rubber button the is pushed in and not touching the buttonpop out the rubber button and put the cap button back and it should turn on and off without a problem
Feb 27, 2008 | GPS
E-Machines eMachines Desktop PC Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
