Question about HEWLETT-PACKARD CP1025nw Laser Printer
How Carousel Alignment Reindexing in hp laserjer cp1026 color
Hp colorlaserjet cp 1025 Carousel Alignment
This printer has no carousel alignment. The toners do not fit into a carousel. This printer has an imaging drum and print cartridges black, cyan. yellow and magenta. Please be more specific about what you are trying to do or what the printer is doing or not doing.
Jul 02, 2014 | HEWLETT-PACKARD CP1025nw Laser Printer
Toner yellow, magenta and black lights are flashing. cannot put in magenta toner as the "arrow" positions are not at the right places.
This sounds like the carousel in the printer has gone out of alignment. This is usually caused by using old generic toner cartridges. ( the roller on the toner cartridge seizes and causes carousel to go out of alignment. )
There are other easy fix instructions on here to realign the carousel.
Jul 17, 2011 | HP LaserJet 2550L Printer
I installed new toner cartridges and a new drum (authentic HP) and my printer won't print. When it is initializing, the sound is different and when I look at the gap between the toner cartridge and the...
On the 2840,one reason why the carousel gets out of alignment is because non HP cartridges were used and they were leaking toner. The leaking toner gets into the carousel gears and causes them to jump a couple of teeth.
If you have a warranty HP will fix the problem under warranty repair. However, if you were using non HP cartridges you will be billed. If your problem is non aligned gears, you won't need parts. The gears will have to be aligned and vacuumed. It doesn't require dismantling the printer.
If you do have to pay, it should only be an hour of labor.
Does it print good? If the printing is good, the carousel isn't out of alignment. Don't fix it if it isn't broke.
Jan 08, 2011 | HP LaserJet 2840 Printer
How, i can get the logiciel for hp laserjer 1020.
The drivers for the Laserjet 1020 can be downloaded here:
http://tiny.cc/97fdl
Jan 28, 2010 | HP LaserJet 1020 Printer
HP Color laserjet 2600 only black print is commong
It a problem with printer fusing assembly. so you can checked it from service center.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
Printing on right side only
It is the carousel that is dislocated. Check the alignment if it's brooken
Nov 01, 2008 | HP LaserJet 2840 All-In-One Printer
Replaced toner but keeps saying replace supply using black only
This happens occasionally with after-market (refurbished) cartridges. Sometimes the people rebuilding the cartridges forget to replace the microchip on the cartridge that resets the copy counter. Most reputable re-manufacturers will send you a replacement cartridge if this happens.
It could also be a carousel alignment or sensor issue inside the printer - if this is the case you will have to call HP for service.
Whatever you do, make sure you do not try to manually rotate the carousel to change out the different cartridges - each time you want to change a specific color, close up the printer first and then press the carousel rotate button that's directly under the ready light, keep pressing until the display says that it's rotating to the color you want, then open and change that color, repeat for each additional color.
Oct 13, 2008 | HP LaserJet 2840 Printer
Prints on Right Half of the page... HP 2820
Here's a copy of the complete HP service manual for your machine. Your problem is the indexing or alignment of the carousel gears. There are timing marks on both sides of the carousel that must mach up with the drive gearing. Kinda like timing chain marks on your car. When the gearing has jumped it increases the gap between the drum and cartridges and prevents the toner from the cartidge from being properly attacting to the drum.
Here's a copy of the complete service manual on your machine. If this helped you, please leave me a FIXYA. I'm just a 13 year veteran tech trying to help people out when I have the time.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Jun 04, 2008 | HP LaserJet 2820 Printer
HEWLETT-PACKARD CP1025nw Laser Printer Logo
113 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
