Question about Pool & Spa
Garden leisure spa
Spa pump makes alot of noise in the low position. Sounds better in the high position, but will lock up when switching betweem the two.
    Problem Solver:
  • 5 Answers
Pump is going out
Posted on Nov 09, 2013
Trying to set my garden leisure spa on sleep so it circulates less. Currently it turn on every hour and runs for 7 minutes.My electric bill is out the roof.
there is a thing called a switch that you can activate to turn it off unless you are using it
That saves about 85% of the power bill
retime the timer to run at longer periods for less time or fit your own timer in the lead to the pump
Apr 20, 2017 | Leisure Pool & Spa
I just bought a used older garden leisure spa, it won;t turn off. The manual says push button once for low pump, twice for high pump and a third time for off. I only get low and high pump speeds.
This can be normal depending in the settings. It may continue to run for upto 15 minutes, its just looking to satisfy it's heat or filter cycle.
Dec 14, 2016 | Pool & Spa
My Leisure spa is giving me an error message: 5LP. What does this mean? Can I fix?
sounds like low pressure check filters if clean check pressure switch
Oct 17, 2015 | Pool & Spa
Garden leisure spa
check to make sure you are getting 220 to it if not the check breacker
Sep 07, 2013 | Pool & Spa
Spa pumps makes alot of noise when set on low. Sounds better when set on high, but will lock up when switching between the two. Garden leisure spa.
Either have the motor rebuilt or replace it. At some point in time you had a pump seal leak which lead to the berrings going out. If you replace the motor be sure to replace the seal as well.
Aug 01, 2013 | Pool & Spa
I have a Waterway Spa Pump Executive 56 Frame 4hp Dual Speed PF-40-2N22C in a Catalina spa that recently developed an issue. The pump will not start in low speed, just makes a humming noise, but it will...
the problem with the sound is the bearings inside the motor are going out. i have the same pump and i have to replace the motor. replacing the bearings is very hard and will cost you about the same after you carry the motor and new bearings to a shop to be pressed in. hope this helps!!
May 04, 2011 | Waterway Spa Pump Executive 56 Frame 4hp...
Pump starts switching between high and low by itself for 45 seconds, then shuts off.
Thank you for posting your question here on Fixya.com.
Is this a two speed pool pump with a toggle switch as part of the motor or a spa pump plugged into a control that uses relays to switch from high to low?
If it is a pool pump you will need a new toggle switch.
If it is a spa unit, replace the relay.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Dec 03, 2010 | Pool & Spa
Pool & Spa Logo
186 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
