Question about Franklin Industries FWC35 Compact Wine Cooler Side by Side
Need replacement condenser fan for motor - Franklin Industries FWC35 Compact Wine Cooler Side by Side
The condenser fan freezes up, I can push start it but it still stops periodically. Is there some maintenance I can do? I have cleaned it up but wondering if there is something I can lubricate
using a spray with tube lightly spray the shaft as it goes into motor and on back if able to spray where shaft ends against back housing ---I've had fans last for long time and others just to late to save it keep in mind if lubing dont work will need to replace it and since you have accessed it changing it is not hard
Jul 12, 2016 | Refrigerators
Everything works. But the fan runs all the time on or off. 25/7
Condenser Fan Motor Operation ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../condenser-fan-motor-operation
Sub?ZeroShould the condenser fan motor on a Sub-Zero run continuously? Why does the fanmotor run all the time? ... Refrigerator or Freezer Fan Switch Information.
Refrigerator Condenser Fan Is Always Running ' Home ...
homeguides.sfgate.com > Insurance & Inspections > Insurance Basics
Refrigerator motors sometimes need troubleshooting over time. ... If the fan isn't shutting off there could be several reasons. ... reason a condenser fan is continuallyrunning within a refrigerator is the thermostat. ... All Fields are required. Name.
Oct 30, 2015 | Refrigerators
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
How to replace condenser fan blower wheel and where can i get one ?
Hello, in order to replace the condenser fan you will need to remove the motor aseembly and use a hub puller to remove the fan blade. When removing the fan blade spraynsome wd- 40 on the motor shaft and then attach the hub puller to remove the fan blade. You csn buy the fan blade at any heating and cooling store.
May 07, 2012 | Continental Heating & Cooling
How to replace the condensor fan on GE Mod.gdl20kcsabs --bottom freezer
How To Replace the Condenser Fan The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it.
If the fan blade is damaged, it can be removed from the fan motor and replaced separately.
Caution:Please read our safety information before attempting any testing or repairs.
cautiontri.gif Before replacing the condenser fan, unplug the refrigerator to avoid an electrical shock hazard.
The fan motor is held in place with screws and possibly a mounting bracket. Remove the bracket and the screws and pull the motor back away from the housing.
The fan motor is connected by two or three wires. Label the wire placement on the motor before disconnecting the wires. The wires are connected to the terminals with slip-on connectors or a plug. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Remove the fan blade from the old motor and install it onto the new motor. Connect the wires to the new motor and install the motor into the bracket or housing. Make certain that all of the screws are tightened securely.
Replace the access cover (if any) and plug in the refrigerator.
Jul 15, 2011 | Refrigerators
Beko frost free fridgefreezer cda543f not freezeing
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced. The part number for the motor is AP117874
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem...
May 07, 2011 | Refrigerators
I have a ge sbs model pcp23shmffbs. the condenser fan motor is running slow, but turning freely. the fan motor is rated at 11.3 volts dc and supply to fan motor is only 6.7 volts. is the condenser fan...
If the motor is running, but running slowly, you will need to replace the motor. If there was a problem with the PCB, (control board) the motor would not run at all and you would see other problems with the refrigerator.
Here is a link to the motor.
Jan 28, 2011 | GE Refrigerators
Kenmore model 3639550610. Ice maker motor and freezer fan motor wont stop. Need to find wiring diagram.
If fridge repair because it is noisy, turning off and on, or running all the time, it could be a sign the condenser fan motor is going bad. Thankfully, this type of repair is not as complicated as some may think. You can check the condenser fan motor yourself and replace it if necessary.
Tools and Materials Needed:
* Multitester
* Screwdriver
* Needlenose pliers
Step 1 - Disconnect the Power
Turn off the power to the refrigerator to prevent electric shock.
Step 2 - Remove the Condenser Fan Motor
The condenser fan motor is located on the bottom of the fridge, most likely toward the back. Heat from inside the fridge is released into the air here. A panel will probably need to be removed to access the motor. Depending on the screw, a screwdriver or nut driver will be required to remove the panel. Find the condenser fan and motor. You can quickly check the fan's operation by seeing if anything is obstructing its rotation. Manually move the fan blades to see if they spin freely. If they do not, you may need to replace the fan. Continue removing the condenser fan motor by taking out the screws that affix it to the mounting bracket.
Step 3 - Test the Condenser Motor
Your condenser fan motor will most likely have 3 wires attached. Some models have just 2. Note which wires are connected from the fan to the motor. Use needle-nose pliers to remove the wire connectors from the motor. Be careful not to damage the wires. After the connectors are removed, use the multitester to check the resistance or passage of electrical current. Set your multitester to ohms.
If the condenser motor has 3 terminals, only the outside terminals need to be checked. The inside one is a ground terminal. Check the terminals by using the multitester probes, touching one probe to one terminal and the other probe to the other terminal. The reading should fall between 0 and infinity. If you reading falls on either 0 or infinity, then the condenser motor is bad and will need to be replaced.
Step 4 - Replacing the Condenser Motor
Condenser fan motors can be ordered from the refrigerator's manufacturer. Once you receive the new motor, check it with your multimeter the same way as the old motor. This will make sure the new motor is in working condition. Attach the wire connectors to the new motor in the identical locations as the old one. You can refer to the new motor's wiring diagram (most likely included with it) if assistance is needed. Now install the new motor under the fridge. Attach it to the mounting bracket using the same screws as before.
Step 5 - Testing the New Motor and Keeping it Efficient
With the new motor connected and attached, turn the power back on. The unit should operate correctly. If it does not come on, check the wiring. Dust and dirt can plug a condenser and affect the fan's ability to discharge heat. Cleaning them several times a year will help the fridge run efficiently.
Hope this help in solving.take care....
Sep 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer won't go below 32 degrees
Need condenser fan for unit to cool properly
Apr 27, 2010 | Amana SXD524VW Side by Side Refrigerator
I have a RUUD Achiever 11 and the outside fan does not come on, and house won't cool. Was told I need a condenser unit. Perhaps I'm overly skeptical, but wouldn't replacing the fan be an easier (and less...
depends on the condition of the unit and if the condenser fan motor is the only problem?
whoever told you that you need a condenser he or she needs to tell you why and point out the issues with what you have seems to me.
to answer your question it would be yes to the fan motor vs.condenser
Jul 05, 2009 | Ruud UBHC Air Conditioner
Franklin Industries FWC35 Compact Wine Cooler Side by Side Logo
Top Franklin Industries Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Franklin Industries Furniture Expert? Answer questions, earn points and help others
