Question about Mitsubishi WS-65807 65" Rear Projection Television
2002 65" Mitsu TV with crackling sounds/sudden onset.
The above TV began to crackle out of all speakers after several very humid days and I was wondering if moisture might be the problem. I checked all connections and the cond. of the wiring which is all okay. I'm at a draw, any ideas?
  • 1,694 Answers
Check wiring lead dress==if someone sloppy was in it prior to you,the audio circuit wiring may be picking up some noise. 2)Or,you should check the hi-voltage jumper wire between xformer and hv divider block.It may be arcing.If so,replace the block and the hv jumper.
Posted on Oct 04, 2007
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
Feb 10, 2013 | Protron PLTV-37 37 in. LCD Television
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
The sound on my laptop has been fine up until a couple of days ago, it makes an anoying crackling sound through both internal speakers and my headphones an i know my headphones are fine,???? help me please
There are several reasons why you could suddenly be getting a crackling noise. My best guess is you have the laptop near some kind of magnetic source - maybe a cell phone? My Boost mobile phone would do this to my speakers. Is this possibly the cause?
Oct 24, 2009 | Microsoft Windows XP Home Edition
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
TV is crackling
From the speakers or from the inside of the unit. On all modes, eg. normal tv + digibox/scart input???
Apr 05, 2008 | Televison & Video
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
My speakers have almost constant crackling noises
Hello, there is no chance that you can fix this problem by replacing speaker wires. Resoldering the output stages as well as area around the microprocesor could be the efficient solution. If you need more info please advice.
Apr 12, 2007 | Sony DAV-BC150 System
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
