How can I slove the error ERR:DATE TYPE when I try to run a program I have written?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
You're attempting an operation that is not valid for a particular data type, like taking the square root of a string or extracting the second character of a floating-point number.
First, localize the error. Find the line number or location of the error, then narrow it down to the operation. Then examine the value(s) being used in that operation and their types. Make sure the operation is valid for that type(s).
Posted on Aug 01, 2013
Software Install expired criteficat
the usual work for this type of err is to change the date on the phone to
when the ceryificate is valid install the app then set the date back to corrent time. try setting your date back to 2010 then try installing again
Aug 21, 2013 | Nokia Lands Phones
How to resolve CODEPLUG ERR on Motorola PTX760
Your radio needs to be reprogrammed or repaired. This type of error can occur for no reason, or during an interruption in programming. Check your programming/test set-up. Do not try to reprogram using the same codeplug (saved version of programming) as previously used, as it may be corrupt. If you cannot get the error to clear with a fresh programming, the radio will need to go to Motorola to have the error cleared.
Best regards.
Apr 12, 2013 | Laird EXL42MX * Motorola PTX760 Motorola...
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 23, 2012 | Microsoft Windows XP Professional
Everytime i try to go on line or use other programs ,instructions pop up saying 0x0437b7c0 referenced memory could not be written
You have a registry error. Go to START>RUN and type in cmd. When it comes up type in CHKDSK /R. Restart your computer and let it run. You should be good after that.
Mar 22, 2011 | Gateway Computers & Internet
How to solve the problem"*.exe
This error is generally an indication that the written program isn't designed to be run in the 32 bit windows environment, the program is corrupted, or an error occured while trying to run the program. It is generally due to an older program being run within windows.
The newer windows versions are mostly 32 bit platforms. Some of the old programs from windows 95 and 98 eras won't work because they are 16 bit programs. Examples may include older programs with a .com extension (which will bring up this error message), or old versions of .exe's written for 16 bit environments.
If the program you are attempting to run is a recent program (came with your version of windows XP or later) then it could be an error at execution or the program is corrupted. If the program is written by a major brand and is relatively new, contact the program's technical support number for help.
If you suspect a program error, try and obtain another copy of the program. Uninstall the current copy of the program, restart your computer, then install a fresh copy. If the error continues after doing this, then contact the program manufacturer's technical support number.
If the program you are using is one of the programs from within windows, (from the system 32 folder for example, and include notepad.exe, msconfig.exe, or other programs that can be selected and run from within this folder) do NOT remove or copy over the program. Some of the programs within the windows sub-directories are older 16bit programs, not designed to run within the 32bit platform. It is recommended to NOT remove any of these programs from the windows sub directories.
Jan 12, 2011 | Computers & Internet
Laptop memory problem.whn i strt lap it sho an err msg .wants to terminate sum progrm bt whn i trminate the programe itagain show the err msg.what should i do?
try booting into safemode log in as administrator, go to msconfig by going into start click all programs accessories, look for the run application in windows in the run fiel type MSCONFIG in the pop up windows click the option selective start up this will disbale all startup item running on your windows backgroung during boot up restart your computer see if it will boot up properly ^_^
Jun 05, 2010 | Lenovo 3000 Y410 Laptop
What is error statemant?
The try...catch Statement The try...catch statement allows you to test a block of code for errors. The try block contains the code to be run, and the catch block contains the code to be executed if an error occurs
Syntax:
try
//Run some code here
catch(err)
//Handle errors here
}try
catch(err)
Apr 03, 2010 | ArcMedia JavaScript Source Code 3000 Pro...
I can't open any progrmas on my TI-84Plus , it only gives : Error and 1:QUIT can you experts help me?THNX
You should give the whole error message.
I created a bogus program and archived it.
Then I tried to execute it. I got the messages: ERR Archived 1:Quit 2:Goto. When I tried to edit it I got ERR:Archived 1:Quit.
Your program is archived. You must unarchive it.
To Unarchive. Press [2nd] [MEM][2:Mem Mgmt/Del] [ENTER]
Scroll down to [7:Pgrm]. Archived programs will have a star at the left. Highlight the program you want to unarchive and press [ENTER]. The asterisk disappears. Press [2nd][QUIT]. Your program is ready to run or to be edited.
Hope it helps.
Sep 23, 2009 | Texas Instruments TI-84 Plus Calculator
Want to workaround Shrinker.err to be able to download programs. Can it be disabled in any way?
I found that "shrinker.err" is an error
that you get if the product PowerZip 4.50
is installed and fails to start. PowerZip is a Windows utility, a compression tool.
The shrinker.err error is corrected in the PowerZip 5.2 release, the newest version
and that should fix your problem.
This program has nothing to do with any virus.
Hope this helps, Please leave rating...
May 02, 2009 | Computers & Internet
VAIO VGN-NR160E
You can slove it from the safemode .There are few methods to slove your problem.
Switch on the system.then press F8 go to safemode and after enter into the windows in safemode goto the unistall the program and uninstall the nero and goto start menu, then run type "mcsonfig" goto startup tab and unselect the all the programs in the start up and reboot the system .try it and inform to the fixya.com
May 14, 2008 | Sony VAIO VGN-NR160ET Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
