Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Contol panel lights are no longer lit; why? - Sub-Zero 650 / O Bottom Freezer Refrigerator
If all the lights are out, check the bulbs. They sometimes get build up on them and need to be wiggled to make better contact. a 1/8 turn will sometimes do the trick. If there is no light, the panel will not illuminate. It is back lit with the 4 bulbs under the plastic top panel. No light, no panel light.
Posted on Feb 02, 2016
  • Sub-Zero Master
  • 842 Answers
Control panel lights are behind the panel, so if the compartment lights are on the panel is lit. If no lights are on when you open the door, check your door switches as you may find the light switch has failed. Look there first, no lights, possible just a bad switch.
Good Luck
Posted on Mar 28, 2014
How do you reset traction control. 07 chevy cobalt lt
Why ? Traction contol light lit ? Probably a DTC'S - diagnostic trouble code , fixing the problem will turn off the light .
Mar 12, 2017 | Chevrolet Cobalt Cars & Trucks
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
Does not turn on
Are there any lights? If not then I would suspect your power supply. If there are lights it is most likelly your power supply but it can also be just about everyother part on that TV. signal board, T-con, power supply. If you need a power supply.
You can get parts at www.interliquidparts.com
Dec 02, 2011 | LG 42LH30 42 in. LCD TV
My washers contol panel is lit and it says control locked how do i get this unlocked
Hi
You can unlock it by pressing the end of cycle signal button and hold if for 15 seconds, this will reset the control. Hope this helps...please post back for further assistance.
Daniel
Aug 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My simer ace in the hole a5000 will not charge my 2.5 year old battery. The battery voltage reads 10.75 volts. I replaced the twelve volt charger and it originaly lit the yellow charging light , but it no...
I does sound like a controller issue. Try testing the charging output (be careful, who knows what the voltage may be coming out) I would say it is the battery but the yellow light thing has me thinking you are right. That thing has been sitting there maintaining the battery for 17 years, it is probably tired. The other bad news is if your battery has been sitting at that low volta.ge it may have a greatly reduced capacity now. Hope this helps some. .
Jun 09, 2011 | Vacuums
The contol lock red light is lit and I can't get it to work
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Could the front contol panel be bad if my T.V. dont turn on
More likely no power to set; either no AC from plug outlet, or internal fuse in power supply.
Apr 19, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Control locked led indicator is on ,there no contol at all
Press & hold the 'end of cycle' button on the right side of panel for 3 seconds. Child lock button, you do the same thing again & it locks. You dont want kids bathing in the machine, no. Pl rate me nice.
May 13, 2009 | Whirlpool GHW9100L Front Load Washer
Windows XP Media Center Remote control wont work anymore
I have solved the problem. All i did was open windows media player and use the remote control to operate it. From then on it worked fine with windows media center. Hope it solves your problem too. good luck.
Nov 24, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
165 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
