Question about Sharp R-820BK Microwave Convection Oven, 0.9 cu. ft. 900W, Carousel turntable system: 12 diameter porcelain enamel 2-line, 12-digit interactive Display, Auto-Touch, Black R820BK R 820BK R820B R820 R-820B R-820
Sharp carousel microwave convection oven keeps blowing fuse
  • Sharp Master
  • 9,047 Answers
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on Sep 23, 2013
4 Suggested Answers
SOURCE: Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Posted on Dec 12, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Posted on Aug 30, 2009
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
I have a sharp carousel but the convection oven is not heating up. The microwave works.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,./';
May 24, 2011 | Sharp Carousel R530EST Microwave Oven
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Jul 07, 2010 | Sharp R-303CW Convection / Microwave Oven
Built-in Sharp Carousel II Microwave Convection Oven died.
There are a couple of safety thermostats in the oven to shut down power if something overheats. One is on the magnetron tube (the microwave source), the other is on the cooking cavity. These sometimes go bad. There's also a power line fuse that may have failed, or become loose in its mounting clips. These can be tested with an ohmmeter; they should all measure very close to zero ohms if they're good.
Another possibility is that the control circuit board in the oven may have failed. I have worked on several Sharp ovens where the power transformer for the board has gone bad for no good reason. If the board goes bad the oven may appear to be dead as well.
Microwave servicing is best left to professionals. If you're thinking of keeping this one, take it to a service shop (or call for home service) and get an estimate. Then decide whether to repair or replace.
Hope this has helped a little. Thanks for using Fixya!
Feb 02, 2010 | Sharp R-1874 Convection/Microwave Oven
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
Sharp Carousel Microwave has no power
I too believe that a "protection fuse" was possibly blown. It would need to be found and get replaced. Hopefully it is just a fuse and nothing else because the way it sounds to me, the microwave may be damaged.
Good Luck!
Jun 11, 2009 | Sharp R-1870 Convection/Microwave Oven
Sharp carousel II microwave/convection oven
The question is... Do you want to put money on a 18year MW, or put it towards a new one? I must admit I love the SHARP Combo MW Convection ovens. I own two. One is almost 25years old. The mechanical Timer Type, but they work great and I can maintain them with 30years ef exrerience. I am now retired.
It does sound like the Magnetronhas broken down, however it could be other things in the Secondary (High Voltage Side). The High Voltage Side is made up of the Secondary HV side of the High Voltage Transformer, A High Voltage Diode, a High Voltage Capacitor, and the Magnetron. The High Voltage Side is DANGEROUS, and CAUTION should be taken to protect yourself against EXTREME HIGH VOLTAGE. unplug from power and DISCHARGE High Voltage Capaciton to frame GROUND before touching anything!!!!
Jan 29, 2008 | Microwave Ovens
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Sharp R-820BK Microwave Convection Oven, 0.9 cu. ft. 900W, Carousel turntable system: 12 diameter porcelain enamel 2-line, 12-digit interactive Display, Auto-Touch, Black R820BK R 820BK R820B R820 R-820B R-820 Logo
239 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
