Question about Ariens Riding Lawn Mower. 46 in. 22 HP Briggs and Stratton
Plastic broken part under the gas pedal rod at the transmission on a 22 hp 46 inch ariens riding lawn mower. Can't find on parts diagraham. Does anyone know what this is.
5 Suggested Answers
  • 7 Answers
SOURCE: Unknown Spring on Ariens Walk Behind Mower (1980's)
there is a hole in the top of the governer it goes in there
Posted on Jun 27, 2010
panilling9
  • 284 Answers
SOURCE: Cleaning
http://themojack.com/
Posted on Jun 29, 2010
  • 202 Answers
SOURCE: I need an owners manual for an Ariens Sierra 1640
Go you to this page and enter your model and serial number:
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=0.8213132047263072&Site=ARIENSS
Good Luck
Posted on Dec 05, 2010
philwalker78
  • 608 Answers
SOURCE: i need to know what type of oil to add to my
Hi, if it has a Briggs and Stratton engine you need sae 30 engine oil. Regards Phil.
Posted on May 01, 2011
Pedal is free- mover does not move
Two possibilities to look for.1. The linkage may have lost a connecting pin. Follow active rods from pedal to control arm on transmission. 2. There is a disengage rod to allow the machine to be pushed without the engine running. If this is in the disengaged position the transmission will not drive. Look at the rear and low down for a lever or rod which is connected to the transmission.
Sep 28, 2014 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Why won't my Ariens 46 in 20 hp BS eng. turn over when key is turned to start?
It could be several things. First see if the safety switches work One switch should be under the seat. The second could be a bad solenoid which will not allow the current to go through the wire. Thirdly the battery connector could have a break in it. Electrical problems can be tricky to track down.
May 18, 2014 | Ariens 46 in. 20 HP Hydrostatic Riding...
Why wont an ariens mower turn over?
dead battery or the brake is not depressed far enough for the safety to not work
May 17, 2014 | Ariens 46 in. 20 HP Hydrostatic Riding...
Yt 3000 42" will not move forward or backward
Your drive belt might be off or broken (upper one) not the belt that controls the blades. There's a rod at the rear of the mower that also controls the trans-axle, if it's pulled out, the transmission is disengaged. To purge air out of the system, you pull the rod out, keep it in the out position with a pin and move the motion lever to go forward and return it to neutral several times, then do the same thing to the reverse direction. Then release the rod and return it to the very most inner position. GOOD LUCK, hope it's not a bad transaxle.
Feb 24, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Ariens hydrostatic slow in drive
sounds like a bad belt i have the 48" it was doing the same thing
or you could have debris in the way of the linkage
Nov 03, 2013 | Ariens Riding Lawn Mower. 46 in. 22 HP...
I cant start the mower. I have charged up battery, checked gas and cant start the thing. What else can I do? It is a 22 HP Airens.
make sure parking brake is set, you are in the seat, the mower engaging lever is in the down position and the the gear box is in Neutral
Sep 25, 2013 | Ariens Lawn Tractor 46"" Riding Lawn Mower...
Ariens 46'' 20 hp Hydro riding lawn mower user manual
my starter just clicks.I bought a new starter and it does the same thing
Jun 18, 2012 | Ariens Garden
Gas pedal does not work on my toro riding mower
If you are talking about the hydro drive pedal the your transmission is bad or the drive belt ripped or run off.
Sam
Aug 08, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Husqvarna yth1842xp 2005 ride on mower won't move in gear
your linkage came apart from the way it sounds. most all these riding lawn mowers are simple machines. you need to fallow the(flopppy lever) and see where it go's it is supposed to attach to a rod or cable and must have came unhooked
May 01, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
Ariens Riding Lawn Mower. 46 in. 22 HP Briggs and Stratton Logo
56 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
