Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Get failed to authenticate when I print from my konica minolta
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 45 Answers
IF YOU HAVE TO PUT IN A CODE AT THE COPIER , THEN IN YOUR PRINT DRIVER UNDER PRINT PREFERENCES THAN BASIC TAB CLICK ON AUTHENTICATION/ACCOUNT TRACK
DEPENDING HOW YOU GOT IT SET UP YOU NEED TO FILL IN THIS PAGE,THIS IS YOUR DEFAULT SETTINGS SO YOU ONLY HAVE TO DO THIS ONCE, IF YOU ALLWAYS PRINT UNDER THE SAME ACCOUNT
Posted on Aug 30, 2013
Gunslinger
  • 62 Answers
SOURCE: Printing from an IBM AS/400 to a Konica Minolta 350 printer
An HP5si PCL5e driver may work for just basic printing.You will not have any extras like finishing or dulpexing.
Posted on Oct 21, 2007
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Konica minolta c652 errorr code c211 - Konica Minolta Bizhub C452 Copier
Your authentication device isn't connected properly or wrong loadable driver or your mainboard have malfunctioned. I'd try re-connecting the authentication device USB connection and try new loadable driver, setup in Service mode and perhaps flashing it with latest firmware could resolve your issue. If all this fails then MFPB is to be replaced.
Sep 21, 2017 | Konica Minolta Office Equipment & Supplies
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
Authentication failed
have the copier adminstrator check the account he has set up for you
Feb 11, 2014 | Konica Minolta Office Equipment & Supplies
KONICA Minolta c450 in Windows Vista
go to the printers and faxes page and in the driver properties click on printing preferences click on authentcation/account track and you should be able to enter you name and password from there unless you may have to be logged on as the administrator on your computer to make these changes
Sep 25, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
We recently started having a problem printing from PCs to a KM C451 with a user/pswd specified -- the print job goes to the "Save" tab on the job history but never prints and does not go to a user box....
This is caps sensitive. Keep this in mind. Also, if you are using Vista, the driver may not be aquiring the setting properly to allow printing using authentication. Check to ensure that the settings for authentication or account track match the settings on the MFP. If this all doesnt work, (depending on the application youa re printing from) try turning "print without Authentication" to allow or enable.
Jun 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
User Auth. for Mac on BizHub C250
setting up auth. on mac requires that you open the doc on appropriate app, on print menu select output method, set auth. credentials, and save. then print. some mac OSX ver. will save others won't. prompting you to set auth, every time you need printing.
Aug 26, 2017 | Konica Minolta bizhub C250 All-In-One...
How to setup account tracking for printing
Account tracking or Authentication is not available in the driver on a Microsoft® Windows Vista™ 32-bit client PC.
Description:
Solution:
CAUSE: Microsoft® Windows Vista™ built-in drivers for Konica Minolta printers are only PPD-based and do not have the Account track and Authentication options.
SOLUTION: Install the Microsoft® Windows XP digitally-signed PCL or PostScript driver which will function on the Microsoft® Windows Vista™ 32-bit client PC.
Note: The latest print drivers are available via the Konica Minolta Download Selector. Access the Selector from the KMBS public site (http://www.kmbs.konicaminolta.us) Support & Drivers tab or from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.-----hope that well help
Oct 17, 2008 | Office Equipment & Supplies
Konica Minolta Bizhub 250 Authentication issue
What you require can be achieved though the "public access" settings. This will allow you to control what can happen without requiring a log in.
Apr 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
123 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
