Question about Dryers
I have a frigidaire affinity dryer model laqe7000lwo that shows door open when I try to start but the door is shut
  • 39 Answers
Sounds like it needs a new door latch sensor..
Posted on Oct 18, 2013
vanni7
  • 163 Answers
SOURCE: frigidaire affinity dryer has power but won't start up the cycle
Hi!!! you have a problem with the thermal fuze change it and you will be okay..
Posted on Jan 21, 2009
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: high efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Posted on May 30, 2009
SOURCE: Frigidaire Affinity Dryer (model LEQ7000ES0)
right now i took the whole bottom apart from the main brain and so far is working good is not turning off now it may work on your too
Posted on Jun 22, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire LAQE8000LW door open message
Affinity Frigidaire dryer says door is open and it is not
Sep 10, 2012 | Washing Machines
Affinity Dryer code E66
It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
Aug 24, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity gas dryer problem
I would bet you need new door lock switch
Jul 13, 2017 | Frigidaire Dryers
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Jun 27, 2009 | Frigidaire Electric Dryer
Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
Sep 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Dryers Logo
156 people viewed this question
Top Dryers Experts
