I cannot use my ethernet cable with my modem. Using my computer wi-fi. Now my printer, which works with a USB cable , does not print. In both cases the computer tells me there is no connection. I have tried new cables, new modem and still nothing.
  • Doctor PC
    Doctor PC Aug 06, 2013
    It is possible that your Ethernet port/card is fry.
  • 7,733 Answers
It is possible the the Ethernet port/card is fry.
Posted on Aug 06, 2013
3 Suggested Answers
1Guru
  • 61 Answers
SOURCE: Cant connect my G5 to the Router to get internet
two things to consider. There are two different types of Ethernet cables out there. Perhaps you have a one way cable for the second one. To test this, unhook the working cable from the mac that gets internet and then hook that one up to the one that doesn't get it. See if it sees the network after a minute. The other issue might be in the Operating System. You might need to make sure that they are both up to date with all of the latest updates installed. (I know, hard to do with out an internet hook up.)
Lastly, make sure you are plugging in the cable to the right place on the back of the router. Seems silly, but some of the best have accidentally put it into a link plug to connect several routers rather than an actual Ethernet plug.
Posted on Dec 24, 2008
Macs R We
  • 481 Answers
SOURCE: Printer fails to print - error code -50
From System Preferences / Printers, delete the printer completely.
If you have the driver installer for the driver you are using, re-launch it and choose the "uninstall" option. If not, you will have to rip out a lot of code by hand -- you will have to search HP's website for the page on how to manually remove traces of old Mac HP drivers.
Download the latest driver for your printer from the HP website. Install if carefully.
After rebooting, go to System Preferences / Printers and re-define the printer. Make sure you use the HP driver, not any of the generic drivers.
This ought to clear the problem.
Posted on Sep 19, 2009
I am trying to scan to my computer from my new Printer EE-2550 Epson printer on Wi Fi and I can not get it going.
Try using your ethernet cable. If it works like that then the problem lies with your wi fi connectivity to computer.
Nov 24, 2016 | Epson Office Equipment & Supplies
Tip
Connecting Two Computers Directly With Cable for a home network
The simplest and easy way to start a home network
The simplest kind and easy to maintain of home network contains exactly two computers. You can use this kind of network to share files, a printer or another peripheral device, and even an Internet connection. To connect two computers for sharing these and other network resources, consider the options described below.
The traditional method to network two computers involves making a dedicated link by plugging one cable into the two systems. Several alternatives exist for networking two computers in this manner: Ethernet crossover cable
Null modem serial cable or parallel peripheral cable
Special-purpose USB cables
Ethernet - Of the above choices, the Ethernet method is preferred as it supports a reliable, high-speed connection with minimal configuration required. Additionally, Ethernet technology offers the most general-purpose solution, allowing networks with more than two computers to be built fairly easily later. If one of your computers possesses an Ethernet adapter but the other has USB, an Ethernet crossover cable can still be used by first plugging a USB-to-Ethernet converter unit into the computer's USB port.
Ethernet crossover cables
Serial and parallel - This type of cabling, called Direct Cable Connection (DCC) when using Microsoft Windows, offers lower performance but offers the same basic functionality as Ethernet cables. You may prefer this option if you have such cables readily available and network speed is not a concern. Serial and parallel cables are never used to network more than two computers.
USB - Ordinary USB cables must not be used to connect two computers directly to each other. Attempting to do so can electrically damage the computers! However, special USB cables designed for direct connection exist that can be used safely. You may prefer this option over others if your computers lack functional Ethernet network adapters.
To make dedicated connections with Ethernet, USB, serial or parallel cables requires
each computer have a functioning network interface with an external jack for the cable, and
the network settings on each computer appropriately configured
One phone line or power cord cannot be used to directly connect two computers to each other for networking.
Connecting Two Computers with Cable through Central Infrastructure
Rather than cable two computers directly, the computers may instead be joined indirectly through a central network fixture. This method requires two network cables, one connecting each computer to the fixture. Several types of fixtures exist for home networking: Ethernet hubs, switches, and routers
USB hubs
Phoneline and powerline wall outlets
USB hubs
Implementing this method often entails additional up-front cost to purchase more cables and network infrastructure. However, it's a general-purpose solution accommodating any reasonable number of devices (e.g, ten or more). You will likely prefer this approach if you intend to expand your network in the future.
Most cabled networks utilize Ethernet technology. Alternatively, USB hubs can be employed, while powerline and phoneline home networks each offer their own unique form of central infrastructure. The traditional Ethernet solutions are generally very reliable and offer high performance.
Connecting Two Computers Wirelessly
In recent years, wireless solutions have enjoyed increasing popularity for home networking. As with cabled solutions, several different wireless technologies exist to support basic two computer networks: Wi-Fi
Bluetooth
infrared
Wi-Fi
Bluetooth
infrared
Wi-Fi connections can reach a greater distance than the wireless alternatives listed above. Many newer computers, especially laptops, now contain built-in Wi-Fi capability, making it the preferred choice in most situations. Wi-Fi can be used either with or without a network fixture. With two computers, Wi-Fi networking minus a fixture (also called ad-hoc mode) is especially simple to set up. How To - Set Up an Ad Hoc WiFi Network
Bluetooth technology supports reasonably high-speed wireless connections between two computers without the need for a network fixture. Bluetooth is more commonly used when networking a computer with a consumer handheld device like a cell phone. Most desktop and older computers do not possess Bluetooth capability. Bluetooth works best if both devices are in the same room in close proximity to each other. Consider Bluetooth if you have interest in networking with hand held devices and your computers lack Wi-Fi capability.
Infrared networking existed on laptops years before either Wi-Fi or Bluetooth technologies became popular. Infrared connections only work between two computers, do not require a fixture, and are reasonably fast. Being very simple to set up and use, consider infrared if your computers support it and you lack the desire to invest effort in Wi-Fi or Bluetooth.
If you find mention of an alternative wireless technology called Home RF, you can safely ignore it. Home RF technology became obsolete several years ago and is not a practical option for home networking.
Try it is the best home network option.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
I have T-Mobile 4g galaxy avant android phone. I do not have coverage n my ares 4 the Internet. Cam I hook WI-FI up 2 my desk top and accessories the inn tenet via my home wi-fi
You can get WI-FI anywhere WI-FI is available with a smart phone.
But if you only have a modem at home and an ethernet cable from the modem to your computer to get internet, then you may not have WI-FI at home.
You'll need to get a wireless router to have WI-FI at home.
Once you do that, you can continue to have your desktop hooked up by the ethernet cable, but you can also install a WI-FI adapter card in your desktop. It will have an antenna on the back of your computer and then you can set it up anywhere in your house and have internet without an ethernet cable.
Mar 16, 2015 | T-Mobile Cell Phones
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
It will not print my document, but will print test pages, from the internet and from other programs. It gives me a message that I need to install my printer (which I did again) but it says there is none...
1. Have we made sure the printer cable is connected to the computer? The cable is sold separately from the printer, generally speaking it is a USB cable. (In most cases this cable needs to be plugged in to the computer and the printer needs to be powered on when running the printer installation software)
2. Of the printer is a Wi-Fi printer you will first need to make sure that you join the printer to the same Wi-Fi network that your computer is joined to.
3. Sometimes even if you have a Wi-Fi printer the manufacturer will require you to connect the printer to the computer just the first time, it gathers information about this Wi-Fi network from the computer and then passes the information to the printer.
4. I have also noticed that in some cases steps all or some of steps 1-3 need to be completed for internet printing to work.
Nov 08, 2011 | Corel WordPerfect Office 12 Home Edition...
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
I have a printer attached via USB to a wi-fi connected desktop in a WGR614g network which supports an additional ethernet-connected desktop and two wi-fi laptops. Can I make the printer wi-fi accessible...
Do a search engine hunt for a "WIRELESS PRINT SERVER" and you'll bring up a Netgear WGPS606 for about $60-80 or a Linksys for $36-150 (the same one :-)).
The Netgear has 2 USB A ports and 4 ethernet ports. You plug in your printer, activate the wireless part to receive a signal and you have a networked USB printer.
I assume the Linksys works exactly the same way, except it may not have the additonal 4-port ethernet switch.
Carl
May 01, 2009 | NetGear WGR614 Wireless Router
WirelessModem
First to clarify; is this a WIRELESS ROUTER?
If it is OK, there are also LAN/ethernet outputs on it as well.
DESKTOP COMPUTERS do not typically contain Wi-Fi apadters or 'antenna', these are in most all laptops made these days.
If you have a wireless Wi-Fi Router then it should be fairly straitforward to connect laptops (Start Menu>Connect To, in Windows)
You may have to either HARD WIRE (ethernet line) or buy an internal Wi-Fi or USB Wi-Fi Adapter/antenna. If it's a fairly recent wireless router this becomes fairly straight forward after that.
Jan 05, 2009 | Computers & Internet
Installation problem
YES!!!!! IT DOES NOT HAVE TO BE A SPECIFIC ETHERNET CORD TRY A REGULAR ONE OUT FIRST IF IT DOES NOT WORK IT WON'T SCREW ANYTHING UP IT WILL STILL BE WORKING JUST FINE SO JUST TRY A REGULAR ETHERNET CORD
Dec 14, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
