Question about MSI Computers & Internet
Laptop white screen
I have peoblem in my laptop the screen is white i cant see any thing in the screen
My phone is 6260 every thing is working but i cant able to see because of white screen so plz help me
my 6260 phone is alive but i cant able to see because of white screen how can i fix this
Apr 28, 2010 | Nokia 6260 Cellular Phone
Swapped lcd screens on my cf-48 toughbook
Maybe you mess some connection of the lcd. Is the lcd has the power indicator? If yes then maybe u can some keys functions such Fn to make display out.
Jan 25, 2008 | Panasonic Toughbook 48 Notebook
We just turned on our Sharp LC-5255U for the first time, and the left half of the screen is solid white. We tried different inputs - still white. Even when the TV menu is up, the white is still there. ...
Yes,this tv have major problems,return it,get a replacment tv.Even they test it at the store nothings wrong,it intermitten peoblems,will show some tmes,sometimes not.
Mar 22, 2010 | Sharp LC52D65U 52 in. LCD TV
Screen turn to white & cant recovery the system
I would reinstall windows sounds like the update corrupted it.
Feb 22, 2010 | ASUS Eee 4G Notebook
Having peoblems with pogo and facebook. Pogo will
A couple of things to try. If things were working normally, and have just started this, then try removing spyware and malware. I recomend using Malwarebytes AntiMalware. Also for Pogo, you need to either turn off your pop-up blocker or better yet just turn it off for Pogo. You can find instructions on how to do this depending on which browser you have by choosing the Help button and then search on popup blocker.
Nov 08, 2009 | HP Compaq Presario dv6693us Notebook
Just replaced the screen in an Acer 5720...it lights up but that is all... is there a reset or function code needed
if you installed the screen yourselfe double check all connections. if you paid someone to install the screen tell them of your peoblem
Sep 15, 2009 | Acer Computers & Internet
White Screen Of Death
Most likely the problem is the screen or other hardware errors.
If it is the screen, then you should be able to see the Hard drive activity LED flashing as things load.
Jul 15, 2008 | Sony VAIO VGN-UX280P Notebook
Peoblem in my shinco PMP-1700 DVD
try lightly pushing the small white button at top right hand corner of touch pad a few times, I have found this normally brings the screen to life again
Mar 14, 2008 | Shinco PMP-1700 Portable DVD Player with...
Thin white line (hoz) across screen (gets on my freaking nerves) this is after i bought it DOA and had to use mini PE to get hard drive to work and then loaded VISTA 5 times and finly it loaded without a...
A Few things you can try,
Updateing Graphics Drivers, Check Connections, Adjust resolution and refresh rate, Connect to another monitor to rule out GPU and Software issues.
Dec 13, 2007 | Acer Aspire 3100-1405 Notebook
Computers & Internet Logo
19 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
