Question about Howard Miller Techtime II 625236 Clock Radio
Our Model 625-236 clock has changed it's time back to winter time. We cannot figure out how to change it back with the selection of buttons on the back. I messed with it enough and evidently set the alarm which went off at 4 am this morning! ugh.
  • Nancy DeMeerleer Aug 04, 2013
    We have fixed it. A lot of pushing buttons and we finally got it.
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
I just had a representative from the Geek Squad set up my Epson WorkForce 633 Fax/Printer/Copier. The time that we set up is not what I wanted. I want a 12 hour set up, and I need to reset the clock on...
Below you will find the instructions straight out of the manual. I have also put a link to the whole searchable HTML manual at the bottom of this post Enter the Date and Time Before setting the date and time, you should select the appropriate Daylight Saving Time setting for your region. This setting lets you easily set the clock one hour ahead or one hour back when the time change takes place. 1. Press the fax.6.7.1.jpg Setup button. 2. Select Printer Setup. You see this screen: fax.6.7.2.jpg 3. Select Daylight Saving Time. 4. Select Summer if your region uses Daylight Saving Time and it's currently in effect. (DST is effective from spring through summer.) Otherwise select Winter to turn off the setting. Note:
When you change the setting from Winter to Summer, the clock is automatically set ahead by one hour. When you change it from Summer to Winter, the clock is set back. The setting is not automatic; you need to change it each season. 5. Select Date/Time. You see this screen: fax.6.7.3.jpg 6. Select the date format. You see this screen: fax.6.7.4.jpg 7. Use the numeric keypad to change the date, then press OK. fax.6.7.5.jpg 8. Select the time format. fax.6.7.6.jpg 9. Use the numeric keypad to change the time, then press OK. 10. Press fax.6.7.7.jpg Back until you return to the home screen. Epson Work Force 633 Manual Hope this helps. Zeppelinx12
Mar 10, 2011 | Office Equipment & Supplies
How do u change the time on the jvc kd-s15?
Press and hold SEL to get to the menu
Using the SCAN (FWD/REV) buttons, select Clock H
Using the volume knob, set its value
Using the SCAN (FWD/REV) buttons, select Clock M
Press SEL to end.
Nov 24, 2009 | JVC AM FM CD DET FACE CAR STEREO
How do you set the clock? Mine is an hour ahead and I can't figure out how to set it back. I don't have a manual either...
1. hold the source button until the radio turns off.
2. then hold the audio button until a menu is displayed, which is normal the clock settings first, toggle through the menu by pressing the audio button again
3. use the arrows to change the time
Aug 14, 2009 | Pioneer DEH-P3700MP CD Player
Clock setting on jvc kd-g140 car audio deck
Press the Mode button (M) and the display will flash mode. Then hold the select button (SEL) until it changes to display something else. Hit left and right seek until you find clock M and clock H. Hit select again and use the volume button to change the time! Took me two freaking hours to figure that **** out.
Jan 11, 2009 | JVC KD-G140 Car CD Player
Atomic clock sky scan model 87801
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
Nov 07, 2008 | SkyScan 86709 Atomic Wall Clock
SHARP AQUOS LC-26P70E - Clock
Most TV's don't change with daylight savings time, since they do not operate with a date, just time. You will need to change it via the remote.
Good luck
Mar 30, 2008 | Televison & Video
Change the time
1 Select Clock Adjustment mode
Press the [FM] or [AM] button.
Select the "CLK ADJ" display.
2 Enter Clock Adjust mode
Press the [4] or [¢] button for at least 2 seconds.
The clock display blinks.
3 Adjust the hours
Adjust the minutes
Press the [4] or [¢] button.
4 Exit Clock adjustment mode
Press the [MENU] button.
Hear is the complete manual.
http://inform3.kenwoodusa.com/manuals%5CKDC-MP225.pdf
Nov 20, 2007 | Kenwood Sirius KDC-MP225 CD Player
Time change on Pioneer car radio
Turn the raido/cd player off. Hit the clock button. Time will display. Press and hold down the audio button for 4 seconds. Use the arrow keys to change time. Press and hold the audio key when finished until the time is done flashing.
Nov 07, 2007 | Pioneer KEH-P2030 Cassette Player
I can't set the clock!
Okay, I had the same problem as well. After reading some solutions that didn't work I figured it out. On the right side of the radio there is a "F" function button on top and "A" audio button on bottom. First turn the radio off. Push the clock button until it is displayed. Then push and hold the "F" function button until the radio comes back on, then release the "F" button for a second and push it again then relase. Now, at this time the radio should only display the clock with the hour blinking. Use the up and down select key to change the time. Then push the right or left select button to change to the minute which will start blinking, then again push the up and down select button to adjust the minutes. When the time is correct just push the clock button and it is set.
Jul 23, 2007 | Pioneer DEH-P4100
Howard Miller Techtime II 625236 Clock Radio Logo
Top Howard Miller Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Howard Miller Audio Player and Recorder Expert? Answer questions, earn points and help others
