Question about Watches
Casio w98h My husband loves this watch. The band broke. Is there anyway I can fix band? And how much?
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
SOURCE: I need to shorten the metal link watch band of my
I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
Thanks,
Steve Zansler
Posted on Jan 02, 2010
  • 103 Answers
SOURCE: My 433lsl black band broke. I can not find a replacement broke
order a replacement band directly from skagen its only $25
http://www.skagen.com/service/home.fx
Posted on Aug 04, 2010
gemineye61
  • 831 Answers
SOURCE: How do I adjust the
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Posted on Aug 21, 2010
    • 101 Answers
    SOURCE: I want to shorten my watch band on my new Casio
    In order to remove the links of your Mtg930 watch you will need a couple of tools . It is recommended to have a watch pin pusher and a spring bar remover tool in order to do so. If you do not you can use a small precision flat head screw driver , the size that is usually used to fix glasses or smaller.
    First you need to lay a cloth down at a table . Lay the watch on top of cloth to prevent scratching . flip the watch upside down and have a good at the back of the watch bracelet.
    If you look carefully you are going to see notches on the back of each link with an arrow pointing in. This is where the spring bars are accessible and can be pushed in to remove the link.
    You need to place your spring bar remover, pin pusher or precision screw drive in the notch against the edge.
    Mean while push the opposite side of the watch link up so you can see the most of the spring bar inside the notch.
    The spring bar is going to look like a pink with a notch on the the top then gets smaller. As shown below on the left side of the picture. If you are looking at the notch on the spring bar, that is where you need to get our tool ontop of . So you can push down the spring bar.
    Once you push down on that notch on the spring bar the link will be able to slip out . Without a spring bar remover it will be more difficult and you will need to be patient as you try to work your flat head screw driver into the notch and be able to push down . Once the pin is push down you need to pull the link from the rest of the bracelet.
    Do not be surprised to take anywhere from 5 to 30 minutes if you have no experience and not have a spring bar remover.
    Once you removed all the links you desire , You will need to put the spring bars back into the links and close the watch bracelet up.
    The easiest way is to slip spring bar into middle of link. Bring the other end of the bracelet over so it the bottom covers the other link with the spring bar head out. Push the spring bar down with your tool as you slide the links back together.
    Posted on Oct 18, 2010
    Broken Casio Wave Ceptor WVA-510A strap
    I found a company in the u.k. www.watchbattery.co.uk, good price on Casio bands, pretty good shipping charges too.
    Nov 29, 2012 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    How do I adjust the band on a Casio AQ 160 watch?
    try this link below there are several diffarant band adjustments that may help you
    http://www.watchmaterial.com/How_to_size_a_watch_band.asp
    Nov 02, 2012 | Casio Watches
    Watch band broke on Forerunner 110
    I have the same problem after 2 years. I just hung up with Garmin and they told me that for $59, and receipt of my watch, they will ship me a refurbished 110 watch with the exact same design (the watch and band are all one molded unit). So, it will most likely happen. I asked the person if they still make this design and was told they do for 3 of their current models. I love the watch, but Garmin may have lost a future customer.
    Jun 11, 2012 | Garmin Forerunner 110 GPS Heart Rate...
    The band for the watch broke. Do you sell bands for the casio AMW 330?
    mcdevito75 here, Hello, Mike D from RITE TIME BASICS, we are listed in the Repair Service Directory right here at fixya. I would need your Casio watch here with me for fitting of the new band, for a few days, I may also have to order a new band for your watch if you wanted a Genuine Casio Band. Bottom of this page, Click on Repair Service Directory, then watches, we are the RITE TIME BASICS email, mcdevito@netzero.com
    Aug 19, 2010 | Casio AMW330-7AV Wrist Watch for Men
    Aug 03, 2010 | Skagen 433LSL Wrist Watch
    Purchase watchbands for the timex 1440 sport
    My son's watch (WR 50M) broke... so I have a strap, if you'd like it.
    He loved this watch and it would cost about the price of a new one to repair, so I'm buying him a new one. He's had the same watch for years... bless, huh?
    If you anywhere I can purchase another WR 50M - 1440 Timex, I'd be most grateful.
    Apr 25, 2010 | Timex 1440 Nylon watch
    Repliciment wrist gand for Casio Pathfinder
    you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
    http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
    Jan 05, 2008 | Casio Casual Sports Watch HDC6007BVCF
    Watches Logo
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
