Question about Radio Communications
Motorola 250 trouble pairing and staying paired
    Master:
  • 623 Answers
The memory battery may be dead.
Posted on Nov 07, 2013
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Motorola 250 manual
I was made to understand that the 250 together with 270SLK, 280 & 289SLK all came out sometime last quarter of 1998. To my knowledge, all share the same basic features. The only difference is that the high end models feature built-in VOX, available colors, power/battery condition indicators, some other frills.
Like you, I couldn’t find any manual for a 250 but the user’s manual for a Motorola Talkabout T-289 is available here. Since most features are presumably the same, you can probably try winging it from the 289.
Here and here are nice articles about the 250.
Hope that this be of some help. Pls post back if this is of any use to you or should you need further information.
Good luck and kind regards.
Posted on Nov 08, 2007
egadgetguy
  • 258 Answers
SOURCE: Same station same code only working one way motorola 250
If one set has FRS and GMRS channels and the other doesn't, the FRS channels may not match. Try using the lower channels or going up or down one channel.
Posted on Aug 15, 2008
eradiostore
  • 1654 Answers
SOURCE: I am trying to pair my motorola walkie talies
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
You will need to program the frequency, code and Qt filter (if any) to match. For basic operation set the frequency and then set the code and Qt filter (if any) to off (zero).
Best regards.
Posted on Apr 15, 2010
I am unable to pair my H720 Bluetooth headset to my LG d500cell phone
Hi Beatrice,
You can check this link H720 Bond Pair for more information about how to pair your Bluetooth device.
Regards,
Maya
Motorola Support
Feb 01, 2016 | Motorola Mobility H720 89382N Bluetooth...
How do I pair with my Motorola e?
Just reboot your Motorola device. And try again. I'm assuming that you re having trouble pairing the devices. If the problem is that this is your first time pairing, then just head over to this link and download the manual.
http://www.lg.com/au/support-product/lg-NB2540
Sep 22, 2015 | LG NB2540 -Sound bar
Motorola h730 after factory reset will not stay paired after closing and opening again
Delete the pairing on the phone and then re-pair. Also ensure your headset is fully charged. It should autopair with your phone after a reset when you open boom if phone has bluetooth turned on and is in range.
Mark
Motorola Support
Feb 10, 2014 | Motorola Mobility H730 Bluetooth Headset
My h700 bluetooth will not go into pairing mode
hi sammieyoungj. i'm sorry to hear about your troubles with your headset. Maybe this will help your situation. Ensure the headset is fully charged. Then turn on the bluetooth feature (discoverable mode/set to look for bluetooth devices) on the phone you are planning to pair it with. Next, turn off the headset by closing the microphone boom. After about 8 to 10 seconds or you know the headset is off, press and hold the call button for about 4 to 5 seconds. The headset should activate and show a steady purplish colored light. When the light turns purple, unfold the microphone boom. If the lights stay a steady purple color, then the headset should be in pairing mode and you can revert to your phone to pair them together.
If the light does not stay steady, or turns a blue color, repeat the steps above, making sure no bluetooth devices are around that it may have paired with previously. Hope that helps. Best of luck.
Mar 05, 2011 | Motorola Mobility H700 Wireless Headset
Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Jun 02, 2009 | Motorola Mobility HS850 Consumer Headset
Bluetooth Motorola Hs801 Pairing
after hs801 is switched on, hold one of the volume buttons till the LED(blue) stays ON, then you can pair device to any phone. Pass code is 0000.
Oct 24, 2008 | Motorola Mobility HS801 Consumer Headset
Connectivy
check the visibilty??
Aug 25, 2008 | Nokia 6126 Cellular Phone
Aug 14, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Purple light on H700 will not stay lit
I was having trouble with the same thing. The light would flash purple when closed, I opened and it stayed lit only for a second. Give it another second, I found it flashed off then came back on steady for pairing mode.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
