Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Dreammaker my dreammaker spa has no power. will not turn on.
    Top Expert:
  • Dream Maker ... Master
  • 8,686 Answers
If voltage to unit check fuses then heating element and pumps
Posted on Sep 20, 2017
4 Suggested Answers
mdhstore
  • 6 Answers
SOURCE: we have a dreammaker spa, how do we drain it? the
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Posted on Nov 01, 2009
  • 279 Answers
SOURCE: My dreammaker spa has power and lights but the
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
Posted on Jan 14, 2010
  • 111 Answers
SOURCE: Topside control issues
Topside control is in "Locked" mode.
If you accidentally locked your control
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position
If these do not help let us know your control make and model & we'll see what we can do to find out more for you.
Posted on Feb 20, 2012
Dreammaker x-400 clicking sound and pump surge
This might be a problem with the topside control. When the spa is clicking, try unplugging the topside control and see whether or not the problem stops. If the jet button is stuck on the topside, the pump will turn on-off-on-off-on-off until the topside is unplugged.
If unplugging the topside worked, replace it.
Apr 11, 2017 | Pool & Spa
Over heating
Try turning the power off and back on again.
If this doesn't solve the problem you have further issues.
Regards,
Ian.
http://hottub.synthasite.com
Feb 12, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dreammaker spa has power and lights but the pump won,t turn on.it makes a sound for a few seconds like it is trying to turn over then it stops.it was recently running .
Jan 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
The pump on my EZspa will not turn on.
Turned out to be a fuse, contacted the local dealer directly and they said dreammaker has changed vendors on the control box unit and
they have been having problems with the 250V 15Amp fuse.
Suggested that I go to a 20Amp, but that I should contact dreammaker
directly
Jan 02, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
51 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
