Question about Seagate 500GB FreeAgent GoFlex Hard Drive
When I format my HARD DRIVE my computer didn't recognize it . i try to re install it but it always appear in dialog box is installation failed ...what can i do??
    Problem Solver:
  • 21 Answers
Make sure when you format it that are choosing between fat / and or ntfs format and check in disk management that the drive has been assigned a letter.
Posted on Nov 12, 2013
melnavz
  • 1226 Answers
SOURCE: Hardrive Partition Is corrupt
As i review your explaination, there might be a problem in your hard drive. There so many problems i encountered in the hard drive i encountered like that. However, some problems can be fix using your solution and the other can be fix by replacing the BIOS Battery, and sometime the error in the hardrive is cause by a memory fault. If you are sure that the memory, motherboard, and the bios battery is good and working properly. I recommend you to replace your hard drive that the inconsistency problem will be fined.
Please do testing of your hard drive by connecting it to the other system.
Posted on Feb 01, 2008
iqbal_del
  • 655 Answers
SOURCE: SEAGATE HARD DISK DRIVE PROBLEM...
grt seagate nice brand...
whenever yor OS is currepted this type of messages raised. its not only due to bad hard drive. I think your hard disk is ok. If you want to make a check you can run scan disk to see if you have any bad-secter on your HDD, if you have then its HDD problem, otherwise its ok.
Thanks
Iqbal
Posted on Apr 01, 2008
Panth3on
  • 71 Answers
SOURCE: it recognizes the new hard drive as a DVD drive
have you partitioned and formated it ? unless you do that to the drive it will not show up with a drive letter in windows. go into control panel, administrive tools, computer management, disk management - there you should see all your drives and you can partiton, format, assign or reassign drive letters to them. hope this solves your problem.
Posted on Apr 18, 2008
  • 8 Answers
SOURCE: disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Posted on Mar 30, 2009
Mr BrokRench
  • 1623 Answers
SOURCE: my hard drive is recognized
You have to have the current drivers loaded on the motherboard for the HDD to be able to load your operating system.
Posted on Jul 16, 2011
Seagate 500GB FreeAgent GoFlex Hard Drive it didn't appear on my computer
RESOLVED!
Just because this starts with the same steps as other solutions does not mean it ends with the same fix.
1. Click Start
2. Right Click Computer: Select Manage.
3. The Computer Management Dialog box will appear.
4. Select the Disk Management Icon located in the right pane of the Computer Management Dialog box.
NOTE: Under volume you will NOT see the Seagate Drive.
5. underneath the volume pane you will see Disk 0, Disk1 and so forth. look for the Seagate drive ... mine was Disk 2.
6. Right Click on the Drive: Select Properties.
7. The "Seagate FreeAgent GoFlex USB Device Properties" will apear. Select the Driver tab.
8. Select the Uninstall Button.
9. Unplug your Seagate external hard drive and plug it back in. This should re-install the Drivers and it should work like it use to.
P.S. Sorry for the bad grammar\spelling.
May 09, 2012 | Seagate 500GB FreeAgent GoFlex Hard Drive
I installed a new hard drive in my PC. It installed itself after I turned on the computer but it doesn't seem to show up on My Computer as a individual drive. BIOS and the Sys Info recognizes there is a...
Are you sure your BIOS is not showing the old hard-drive you had before you installed the new one?
On the new hard-drive you bought, do the following step
there should be a jumper that came with it, put the jumper to "master",
if that didn't work, put it to "slave", if that didn't show up, put it to "cable select" and try it.
If all failed, totally remove the jumper and try.
Also check in the BIOS to make sure that the Drive is not disabled.
This seems to be a problem from the jumper.
Please rate 4 stars if this helped you.
Apr 26, 2011 | Seagate HDD 1TB 7200RPM SATA600 32MB 3YR...
How to install microsoft office
Insert the installation CD and wait for the setup wizard to load. After you insert the installation CD into your computer's CD-ROM drive, a dialog box will appear prompting you to begin installation. If this dialog box does not appear, double-click your CD drive and explore the contents of the CD. Double-click the file called "setup.exe" to start installation.
Select an installation type. In the setup wizard, click the "Next" button until the dialog box asks you to select an installation type. You must select either "Minimum," "Typical" or "Advanced" installation. Although the "Typical" installation is recommended, you can select "Minimum" if you wish to use as little hard disk space as possible to install Microsoft Office XP. Selecting "Advanced" will require you to select individual components you wish to install. Do not choose this installation type if you are unfamiliar with these components.
Finish the setup wizard and restart your computer. Click "Next" and wait for the progress bar to indicate that the installation was successful. Click "Finish" to close the dialog box and finish installation. When the dialog box closes, restart your computer
watch this video also
i hope this helps you
please feel free to message me you have any trouble installing your microsoft office and ill try to help you in the best way that i can.
Mar 24, 2011 | Microsoft Computers & Internet
Sd card format software
Start up a computer with Windows XP, Vista, or Windows 7. Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Computers & Internet
What to do if bootmanager fails?
hi frenofurs05,
Thank you for the post.
I suggest trying the following methods to troubleshoot the issue:
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows Vista installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Method 2: Rebuild BCD
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec /RebuildBcd , and then press ENTER.
Method 3: Use the Windows Recovery Environment (WinRE) to run System Restore ============================================
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Note:I just pasted this answer from other person cause its very long when i will wrote it and i think the better one than my explanation.
regards,
mastergani
Jan 03, 2011 | Toshiba Satellite L500 Series Notebook
Asks me to When I run my recovery disk that Acer sent me this is what occurs, System disk runs and loads fine I F12 as instructed by Acer and then wait Asks what language I want instruction in I choose...
Either you DVD is corrupt, OR the DVD reader is not working correctly. It seems the reason the restore failed, is that it "Thinks" the Hard Drive is corrupt, too corrupt to replace the OS on...
The only thing to try now, is to get a Windows install DVD, put DVD in drive and boot from the DVD, then try to install with that, when you get to installing and it asks if you want to Format, do so, format Full NTFS. Then try to proceed to installing. If this too fails then you will need to replace your hard Drive, quite a simple matter.
Mar 06, 2010 | Microsoft Windows Vista Home Premium with...
I want to install again the WINDOWS 2000 Professional and i can't do it because it shows a blue image and says that i've to put the win 2000 pro disk on the diskdrive and i put. when i go to the...
What is the boot order in the BIOS? Set that to 1=FDD 2=CD-ROM 3=HDD
While the PC is still on, put the Windows CD in the drive
Restart the PC, watch the screen for a prompt to boot from cd - press a key
The installation will start, you will need to choose where to install Windows
If you do not need to save any data, format the C: drive and install window there.
Follow the prompts the rest of the way through the installation.
You will need to enter the Windows License code at some point.
It is a good idea to change the regional settings to match your location and how you want the date and time formatted.
Most things should be detected and installed automatically, so you are safe to accept the defaults.
After about 45 minutes you will need to restart the PC and then you should be ready to enjoy Windows 2000.
Be sure to go to Windows Update and install all of the patches.
Good Luck and let me know how it goes.
~ Spoem
Mar 24, 2009 | Toshiba Portege 3110CT Notebook
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
Quick verse 7
Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
Seagate 500GB FreeAgent GoFlex Hard Drive Logo
42 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
