Question about iflo Home
I HAVE A IFLO `RENNES` P SHAPED BATH AND CURVED MATCHING SCREEN,THIS WAS FITTED IN 2006. I NEED TO REPLACE THE HINGES.FOLLOWING MANY INQUIRES WITH LOCAL SUPPLIERS I AM UNABLE TO GAIN ANY CLEAR ANSWERS FROM THEM.CAN YOU SUPPLY ME WITH THE REPLACEMENT HINGES.? IF THERE IS A NUMBER OF DIFFERENT TYPES OF HINGES I WOULD BE HAPPY TO BUY A RANGE OF HINGES AND RETAIN THE SURPLUS TO MY NEEDS.I HAVE LOOKED TO BY A NEW IFLO SCREEN BUT THE REPLCEMENT 2011 MODEL HAS A DIFFERENT PROFILE.I WOULD BE EXTREMELY GRATEFULL IF YOU CAN HELP ME WITH THIS ISSUE .MANY THANKS ,RICHARD HALL.
  • 11 Answers
SOURCE: need part number for a kenmore range clock/timer replacement
part #496225
Posted on Dec 05, 2007
SOURCE: hampton Bay Ceiling fan
The replacement remote will work fine. All you have to watch out for is that the remote receiver and the remote transmitter are a matched set.
Posted on Sep 16, 2008
  • 323 Answers
SOURCE: Need to replace drop in range
All you have to do is make sure you have the same drop in top as the hole cut for it. Measure the opening, and then measeure flange to flange on the one you have. The flange will be 1/2" or so bigger than the hole; that's what holds it in.
They are ususall 30 or 36" wide. It doesn't have to be a Kenmore, just match the color to everything else.
Need to know how to disconnect it?
Dan
Posted on May 11, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
SOURCE: ETEC 50" PLASMA TV MODEL #PH-50FB31. NEED: POWER SUPPLY
I have this part for sale!! If you haven't found a solution, let me know. The only problem, is i'm in France. Depends how bad you need it i guess!
Ps it's a new item
Leon
Posted on Nov 30, 2009
How do I wire up my IFLO TIMESWITCH 24hr 7 day
put the wire to the connector of iflo time switch . then install a on-off .that's ok ..
bathroom light
May 15, 2012 | iflo Home
Replace the existing gold hardware in our Jacuzzi with brushed nickel hardware
There are no easy answers to this. You will need to go out and find the handle you want and the find a seat with matching hinges. Your best place will be a Plumbing supply house that can order matching hardware for you. This will let you pick just what you want and it will all match. I'm sorry but I don't think your local hardware store will do.
Mar 19, 2011 | Jacuzzi Home
Single handle shower/bath faucet is dripping. Want
I can fix this.
What is the last thing you did before this problem started?
Jan 13, 2011 | Delta Faucet Delta 172-SSWF Waterfall...
How do I remove the glove box? I want to replace the cabin air filter.
Just to let everyone out there know that in a 2006 Kia Sorento you have to really tug hard upwardly to pop off the 2 plastic "C" shaped hinges off of the small plastic rods on both sides of the glove box after removing the cable (use needle nose on the cable). Be careful as I put some silicone on the tabs to help get it back on.THERE IS NO CABIN FILTER IN THE 2006!! I even had a dealer tell me they had one. Trust me on this. You will even find them for sale.
Dec 05, 2010 | 2006 Kia Sorento
I have just had an iflo metal bath installed but am unsure what products should be used to clean it
When cleaning your metal bath you should clean your bathtub with a non-abrasive soap. Dishwashing detergent such as Joy®, Palmolive®, Ivory®, etc and a soft sponge or cloth is all that you need. If you spill something on the bathtub and need something stronger, the following are SAFE to use: Fantastic®, Tackle®, Top Job®, Formula 409®, ScrubFree®, Calgon Bath®, Windex®, Clorox Bleach®, Spiffits® Bath, Glass Plus®, and **** & Span Powder®.
DO NOT Clean Your Acrylic Bathtub with Paint Thinner, Goof OFF®, Scrubbing Bubbles®, Acetone, Lacquer Thinner, M.E.K. ® or other chemicals that attack the structural integrity of plastics (including, but not limited to, acetones). Use of these chemicals will destroy the acrylic surface of your bathtub and there is no way to reverse the damage caused by this type of chemical reaction. Use of these chemicals will void your warranty.
Oct 25, 2010 | Home
Oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
Liftgate hard to raise . Worked fine when left with dealer for the day for interior detailing. When picked up, liftgate hard to raise. Are there any locking or adjustment screws that could have been...
the liftgate is fitted with two compressed gas support arms.;one or the two are exhausted/need [replaced]these arms have no adjustment you must replace.adrian.;;;;
Nov 08, 2009 | 2006 Pontiac Vibe
In my bath the shower and/or tap on/off and temperature control unit is fitted independently on the wall. The plastic plaque covering the plumbing connection has progressively become cracked in three...
You will probably find, that the unit is 'Obselete'
And replacement parts, are not being produced anymore.
Why not change the broken piece, & do some fancy tiling around it.
I recently tiled around a circular mirror in bathroom, and actually it almost looks like a window.
As long as your 'finishing' is up to scratch.
Good luck with that, & don't forget to rate:)
Jul 28, 2009 | Home
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Replacing AC/heating fan -94 MB 300 TDT
The heater fan is located under the plastic panel at the bottom of the windscreen. To change it start off by lifting the bonnet until it's completely vertical (lift it open then press the "Tabs" on the bonnet hinges), next pull off the rubber seal that runs across the bulkhead. Undo the x head screws that secure the plastic panel, there are also 2 white plastic clips which just pullout towards the engine (they may have aleady been lost if the cars ever had a new wiper motor fitted). Once the the plasic panel is out of the way, remove the wiper mechanism and below it you will see a curved black plasic panel. The heater motor is below that. It's held by 3X 7mm bolts on the left side. Good luck!
Oct 09, 2008 | 1994 Mercedes-Benz E-Class
Home Logo
153 people viewed this question
Top iflo Home Experts
Donni Steen
Tom Chichester
Are you an iflo Home Expert? Answer questions, earn points and help others
